Eminence IMPERO 18C 18" High Power Driver Speaker 4 Ohm 1200W
Brand:|Model: IMPERO 18C|Part # 290-698
The Eminence Impero 18C 18" pro woofer features a 4 ohm impedance, 1,200 watts RMS power rating, and a powerful magnet structure that helps this serious transducer move vast volumes of air.
List Price$294.99
Regular Price$264.99
You Save10%
Sale Price
$238.49
Part # 290-698
  • Ultra-high power handling capacity guarantees long-term durability
  • 4" diameter copper voice coil on fiberglass former, 4 ohm impedance
  • Weather-resistant paper cone and dust cap, treated cloth edge
  • Die cast basket is light yet strong, ready to handle rough travel
  • Massive, optimized motor structure helps move serious volumes of air
  • Capable of sustaining thunderous levels of sub-bass
  • Hand built in the USA
The Eminence Impero 18C 18" high power pro audio speaker is optimized for use in vented enclosures. Its 1,200 watt continuous power rating is a result of Eminence's extensive experience designing and manufacturing loudspeaker drivers for serious professional use.
This 18" cast frame transducer features a 4" diameter copper voice coil that is wound on a fiberglass former. A large magnet, extended and vented pole piece, bumped back plate, and 1/2" thick x 7-1/2" diameter top plate ensure substantial motor strength, resulting in tremendous bass output.
The Impero 18C's performance is ideal for 4 ohm full-range 3-way boxes, bass guitar boxes, and compact to medium-sized subwoofer speaker systems. Recommended enclosure volume: Vented: 113.2 ~ 277.5 liters / 4 ~ 9.8 cu. ft.
  • Nominal Diameter18"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2400 Watts
  • Impedance4 ohms
  • Frequency Response36 to 820 Hz
  • Sensitivity94.5 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight109 oz.
  • Resonant Frequency (Fs)31 Hz
  • DC Resistance (Re)3.13 ohms
  • Voice Coil Inductance (Le)1.09 mH
  • Mechanical Q (Qms)10.13
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)11.20 ft.³
  • Mechanical Compliance of Suspension (Cms)0.17 mm/N
  • BL Product (BL)16.10 Tm
  • Diaphragm Mass Inc. Airload (Mms)148g
  • Maximum Linear Excursion (Xmax)8.13 mm
  • Surface Area of Cone (Sd)1159 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18"
  • Baffle Cutout Diameter16.56"
  • Depth8.31"
  • # Mounting Holes8
  • Sealed Volume2.32 ft.³
  • Sealed F375 Hz
  • Vented Volume5.06 ft.³
  • Vented F345 Hz
  • BrandEminence Speaker
  • ModelIMPERO 18C
  • Part Number290-698
  • UPC876358002061
    (2 Reviews)
  • Weight30.8 lbs.
View similar products to the Eminence IMPERO 18C 18" High Power Driver Speaker 4 Ohm 1200W
