Eminence IMPERO 18A 18" High Power Driver Speaker 8 Ohm 1200W
Brand:|Model: IMPERO 18A|Part # 290-696
The Eminence Impero 18A 18" 8 ohm pro woofer features a 1,200 watts RMS power rating and a powerful magnet structure that helps this serious transducer move vast volumes of air.
- Order Soon - Only 2 Left In StockMore Due In November 4, 2016
List Price$294.99
You Save10%
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-696
  • Ultra-high power handling capacity guarantees long-term durability
  • 4" diameter copper voice coil on fiberglass former
  • Weather-resistant paper cone and dust cap, treated cloth edge
  • Die cast basket is light yet strong, ready to handle rough travel
  • Massive, optimized motor structure helps move serious volumes of air
  • Capable of sustaining thunderous levels of sub-bass
  • Hand built in the USA
The Eminence Impero 18A 18" high power pro audio speaker is optimized for use in vented enclosures. Its 1,200 watt continuous power rating is a result of Eminence's extensive experience designing and manufacturing loudspeaker drivers for serious professional use.
This 18" cast frame transducer features a 4" diameter copper voice coil that is wound on a fiberglass former. A large magnet, extended and vented pole piece, bumped back plate, and 1/2" thick x 7-1/2" diameter top plate ensure substantial motor strength, resulting in tremendous bass output.
The Impero 18A's performance is ideal for full-range 3-way boxes, bass guitar boxes, and compact to medium-sized subwoofer speaker systems. Recommended enclosure volume: Vented: 113.2 ~ 277.5 liters / 4 ~ 9.8 cu. ft.
  • Nominal Diameter18"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2400 Watts
  • Impedance8 ohms
  • Frequency Response39 to 820 Hz
  • Sensitivity95.9 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight109 oz.
  • Resonant Frequency (Fs)33 Hz
  • DC Resistance (Re)5.41 ohms
  • Voice Coil Inductance (Le)1.47 mH
  • Mechanical Q (Qms)14.02
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)11.20 ft.³
  • Mechanical Compliance of Suspension (Cms)0.17 mm/N
  • BL Product (BL)18.90 Tm
  • Diaphragm Mass Inc. Airload (Mms)140g
  • Maximum Linear Excursion (Xmax)8 mm
  • Surface Area of Cone (Sd)1159 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18"
  • Baffle Cutout Diameter16.56"
  • Depth8.31"
  • # Mounting Holes8
  • Sealed Volume4.14 ft.³
  • Sealed F363 Hz
  • Vented Volume11.04 ft.³
  • Vented F334 Hz
  • BrandEminence Speaker
  • ModelIMPERO 18A
  • Part Number290-696
  • UPC876358002054
  • Weight31.15 lbs.
View similar products to the Eminence IMPERO 18A 18" High Power Driver Speaker 8 Ohm 1200W
