Eminence IMPERO 15A 15" High Power Driver Speaker 8 Ohm 1200W
Brand:|Model: IMPERO 15A|Part # 290-692
The 1,200 watts RMS Eminence Impero 15A 15" 8 ohm pro speaker has an extended frequency response that goes low and high, making it perfect for use in small vented boxes crossed over to conventional-sized horns.
- Order Soon - Only 3 Left In Stock
List Price$284.99
You Save16%
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-692
  • Ultra-high power handling capacity guarantees long-term durability
  • 4" diameter copper voice coil on fiberglass former
  • Weather-resistant paper cone and dust cap, treated cloth edge
  • Die cast basket is light yet strong, ready to handle rough travel
  • Massive, optimized motor structure helps move serious volumes of air
  • Smooth response up to 2 kHz makes 2-way system designs easy and effective
  • Hand built in the USA
The Eminence Impero 15A 15" high power pro audio speaker is optimized for use in vented enclosures. Its 1,200 watt continuous power rating is a result of Eminence's extensive experience designing and manufacturing loudspeaker drivers for serious professional use.
This 15" cast frame transducer features a 4" diameter copper voice coil that is wound on a fiberglass former. A large magnet, extended and vented pole piece, bumped back plate, and 1/2" thick x 7-1/2" diameter top plate ensure substantial motor strength, resulting in tremendous bass output.
The Impero 15A's performance is ideal for full-range 2-way top boxes, 2-way boxes over subs, 3-way boxes, bass guitar boxes, and compact subwoofer speaker systems. Recommended enclosure volume: Vented: 53.8 ~ 184.0 liters / 1.9 ~ 6.5 cu. ft.
  • Nominal Diameter15"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2400 Watts
  • Impedance8 ohms
  • Frequency Response46 to 2,000 Hz
  • Sensitivity95.6 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight109 oz.
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)5.42 ohms
  • Voice Coil Inductance (Le)1.47 mH
  • Mechanical Q (Qms)15.33
  • Electromagnetic Q (Qes)0.40
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)5.03 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)19.18 Tm
  • Diaphragm Mass Inc. Airload (Mms)101g
  • Maximum Linear Excursion (Xmax)7.30 mm
  • Surface Area of Cone (Sd)856.3 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.22"
  • Baffle Cutout Diameter13.99"
  • Depth6.56"
  • # Mounting Holes8
  • Sealed Volume1.5 ft.³
  • Sealed F388 Hz
  • Vented Volume3.66 ft.³
  • Vented F349 Hz
  • BrandEminence Speaker
  • ModelIMPERO 15A
  • Part Number290-692
  • UPC876358002030
  • Weight27.5 lbs.
View similar products to the Eminence IMPERO 15A 15" High Power Driver Speaker 8 Ohm 1200W
