290-551_ALT_0
Eminence H2EA 2" Cast Aluminum Exponential Horn 60x40
Brand:| Model: H2EA
Cast aluminum construction and skilled use of finite element analysis ensure the Eminence H2EA 2" exponential horn delivers reliable, tightly controlled sound reproduction in portable and permanent applications.
  • FEA-optimized aluminum design is durable and hi-fi sounding
  • High gain design is ideal for long throw applications
  • Tightly controlled directivity reduces destructive interactions between adjacent loudspeakers
  • Heat sink property provides additional cooling to hardworking high frequency drivers
  • Industry standard 2" throat, 4-bolt mounting for large format HF drivers
290-551
Weight: 4.55 lbs.
IN STOCK
$59.99
Part # 290-551
The Eminence H2EA 60° x 40° 2" horn features durable cast aluminum construction and an exponential flare geometry that optimizes acoustical loading and high frequency efficiency. Although its mouth area requires minimal baffle space, the H2EA horn operates down to 700 Hz and provides excellent functionality when deployed in venues of any size. A 60° x 40° dispersion pattern maintains maximum directivity and gain, keeping the horn's coverage well-controlled and focused.
In addition to the aluminum horn body's high mechanical strength, its ability to couple to high frequency drivers thermally results in a measured 25°F reduction in operating temperature. The utility of this heat sink advantage is especially obvious when using neodymium drivers, and results in improved reliability and reduced power compression.
Thanks to extensive FEA-optimized testing, as well as extensive listening evaluations, the Eminence H2EA reproduces its intended frequency range without coloration, diffraction effects, or distortion. Recommended for pro audio multi-way loudspeakers, stage monitors, and high output cinema systems.
Specifications: • Horn type: Exponential • Minimum frequency: 700 Hz • Nominal dispersion: 60° H x 40° V • Throat diameter: 2" • Mounting type: 4-bolt • Dimensions: 12.4" W x 7.3" H x 6.1" D • Cutout dimensions: 11.3" x 6.3" • Weight 4.9 lbs.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionAluminum
  • BrandEminence Speaker
  • ModelH2EA
  • Part Number290-551
  • UPC876358000487
  • Product CategoryHorns & Waveguides
    (4 Reviews)
  • Weight4.55 lbs.
View similar products to the Eminence H2EA 2" Cast Aluminum Exponential Horn 60x40
in the Horns & Waveguides product category.
Eminence H2EA 2" Cast Aluminum Exponential Horn 60x40 is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from cut through the din mids & highsBolted this horn to a PRV D3220 neo driver, put it in a tri-amped system crossed at 1300 HZ. Ran the RTA, cut 2.5k and 3.1k a smidge, boosted 4k and 5k a bit and added about 6dB at 12.5k. The horn (with this driver) sounds very good at high volume. Minimal distortion, controlled off-axis response. Beefy construction, esp. flange thicknesses. Bolt holes will allow a 1/4" fastener. Two thumbs and a grin!!
Date published: 2014-08-29
Rated 5 out of 5 by from LOS RECOMIENDO MUCHO Y SU SONORIDAD VERY GOODA TODA PERSONA QUE TENGA SU DRIVER DE 2 PULGADAS,POTENCIARA SU SONIDO A UN 100% YA QUE SU CONTRUCCIÓN DE ALUMINIO BIEN TRATADO ES EXCELENTE
Date published: 2014-07-12
Rated 5 out of 5 by from Hi Fi Pro Audio gear - home or touringI use this in an experimental JBL 43XX rig for home Hi Fi. This may be the best exponential short horn for use above 1000 Hz I have heard. Low distortion, natural sounding. Try it in the vertical position as well! Interesting. An upgrade from the old JBL exponential horns - probably benefiting from recent computer modeling tools. The horn provides excellent imaging for Hi Fi use and projects like crazy. Not for the the timid. Overall very musical - a different animal from current bi-radial / wave guide offerings; excellent hi frequency output / projection with good dispersion. Interesting horn for home Hi Fi experimenters and general pro audio use. Solid construction.
Date published: 2013-10-29
Rated 5 out of 5 by from Great quality and valuePurchased this for an experimental upgrade from a 3-way cab with 1" horn to a 2-way with 2" driver. What can I say? Very robust construction. Matched my cab perfectly. I will mod the 2nd cab and be building more. Size is great for monitor or small, short to medium throw top box cabs.
Date published: 2012-05-14
What are the Exact Dimentions?
The product title states 60X40, In what units? It seems unlikely that this in in CM, the 2" hole seems to be pretty well centered, if the picture is at all to scale, i would say that this would be closer to 30cm.
Asked by: Austin P
When they state 60x40 on a horn like this they are referring to its dispersion pattern in degrees, so 60° x 40°. The actual dimensions are 12.4" W x 7.3" H x 6.1" D.
Date published: 2012-11-15
Customer projects that include: Eminence H2EA 2" Cast Aluminum Exponential Horn 60x40
