Eminence Eminator EM:200S 90° x 90° Bi-Radial 1" Horn
Eminence Eminator EM:200S 1" Bi-Radial Horn 90 x 90
Brand:| Model: Eminator EM:200S
Eminence's Eminator® EM:200S super tweeter horn features a 90° x 90° bi-radial "baby butt cheek" design, providing wide, even coverage in both the horizontal and vertical planes.
290-713
Weight: 0.45 lbs.
IN STOCK
List Price$19.99
You Save25%
$14.99
Part # 290-713
Specifications: • Throat diameter: 1" • Driver mounting: 1-3/8"-18 TPI • Nominal coverage: 90° horizontal x 90° vertical • Lowest recommended crossover: 1,300 Hz • Dimensions: 5-15/16" H x 5-15/16" W x 4-1/4" D • Cutout dimensions: 4-1/8" H x 4-1/8" W.
Born from a heritage of quality, value, and reliability, the Eminator® Series from Eminence is a sound barrier breakthrough for car audio enthusiasts everywhere. The Eminator® Series is skillfully designed with the same pro audio engineering that has made Eminence the most trusted brand in the speaker industry for nearly half a century. Eminence built its reputation in the car audio category over the last 25 years by building speakers for some of the biggest names in the business, including Pyramid, Crunch, Earthquake, Lanzar, and Hifonics. Don't just hear the music, feel it with Eminator®.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandEminence Speaker
  • ModelEminator EM:200S
  • Part Number290-713
  • UPC876358001804
  • Product CategoryHorns & Waveguides
    (2 Reviews)
  • Weight0.45 lbs.
View similar products to the Eminence Eminator EM:200S 1" Bi-Radial Horn 90 x 90
in the Horns & Waveguides product category.
Eminence Eminator EM:200S 1" Bi-Radial Horn 90 x 90 is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Eliminator EM:200S Bi-radial 1" hornWith a small amount of fitting, the horn works great on MyBIC Venturi Speakers and it was a way to get that incredible catalogue that came with the shipment. Thanks, I'll be shopping thru this source in the near future.
Date published: 2013-05-19
Rated 4 out of 5 by from Compared to the others this seems the best.Just spent a whole day testing smaller horns, less than 7 inches in the minor dimension at the mouth. This is the only one that even approximated constant directivity. All the rest except one were flat on axis, some amazingly flat (aluminum tweeter). This fine flare is the same frequency response on axis as it is 30 degrees off one axis and almost the same as 30 degrees off the other axis. Also, of course, in the same phase with similar bandwidth. The curve was very easy to EQ to flat with a CD filter. Definitely has a wide and narrow way somewhat suitable for directional control. With no other choice in a small flare other than waveguides and multi-rate type this is the clear winner at PE if one seeks a smaller CD style continuous rate flare. Bolt on version is not available... to bad. Would suggest use with a bigger than 1" diaphragm driver for the full effect.
Date published: 2011-03-09
Lowest recommended crossover?
The PE site here says 3,500hz but the Eminence site says 1,300hz.
Asked by: Kwikas
I am sorry for the confusion, We will check with Eminence and get this corrected as soon as possible.
Answered by: Chrisf
Date published: 2013-06-20
Does it fit to the Goldwood GT400CD piezo horn tweeter?
I'm planning to buy this piezo tweeters due to its great reviews, for my next projet... Does this horn fits to this bullet piezo horn driver? Thank you very much!!
Asked by: Cruz
Yes, those two products fit together just fine.
Answered by: RussR
Date published: 2012-04-05
Customer projects that include: Eminence Eminator EM:200S 1" Bi-Radial Horn 90 x 90
