Eminence Delta-15LFA 15" Low Frequency Driver
Brand:|Model: Delta-15LFA|Part # 290-417
The Eminence Delta-15LFA 15" speaker's performance is optimized for high power bass in sound reinforcement systems, bass guitar combos, club music systems, and stage monitors.
List Price$99.99
You Save10%
$89.99
Part # 290-417
  • Kapton coil former
  • Polyamide-imide coated copper voice coil
  • Ferrite magnet
  • Vented and extended pole piece
  • Pressed steel basket
  • Paper cone
  • Cloth double half-roll surround
The Eminence Delta-15LFA 15" speaker's performance is optimized for high power bass in sound reinforcement systems, bass guitar combos, club music systems, and stage monitors. Eminence LF models are specifically designed with extended Xmax to deliver more bass than standard models and provide "a true woofer" for three-way applications. Made in the USA. 7-year manufacturer's warranty!
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response42 to 3,200 Hz
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight56 oz.
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)6.11 ohms
  • Voice Coil Inductance (Le)1.37 mH
  • Mechanical Q (Qms)6.30
  • Electromagnetic Q (Qes)0.52
  • Total Q (Qts)0.48
  • Compliance Equivalent Volume (Vas)8.51 ft.³
  • Mechanical Compliance of Suspension (Cms)0.23 mm/N
  • BL Product (BL)14.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)75g
  • Maximum Linear Excursion (Xmax)4.8 mm
  • Surface Area of Cone (Sd)873 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.15"
  • Baffle Cutout Diameter13.87"
  • Depth6.3"
  • # Mounting Holes8
  • Sealed Volume4.91 ft.³
  • Sealed F362 Hz
  • Vented Volume13.63 ft.³
  • Vented F331 Hz
  • BrandEminence Speaker
  • ModelDelta-15LFA
  • Part Number290-417
  • UPC876358000272
    (13 Reviews)
  • Weight14.9 lbs.
View similar products to the Eminence Delta-15LFA 15" Low Frequency Driver
