Eminence Delta-12LFA 12" Low Frequency Driver
Brand:|Model: Delta-12LFA|Part # 290-416
The Eminence Delta-12LFA 12" speaker is designed to provide high power bass in sound reinforcement systems, bass guitar combos, club music systems and stage monitors -- night after night!
List Price$94.99
You Save11%
$84.99
Part # 290-416
  • Kapton coil former
  • Polyamide-imide coated aluminum voice coil
  • Ferrite magnet
  • Vented and extended pole piece
  • Pressed steel basket
  • Paper cone
  • Cloth accordian surround
The Eminence Delta-12LFA 12" speaker is designed to provide high power bass in sound reinforcement systems, bass guitar combos, club music systems and stage monitors -- night after night! Eminence LF models are specifically designed with extended Xmax to deliver more bass than standard models and provide "a true woofer" for three-way applications. Made in the USA. 7-year manufacturer's warranty!
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response44 to 3,000 Hz
  • Sensitivity94.6 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight56 oz.
  • Resonant Frequency (Fs)51 Hz
  • DC Resistance (Re)6.06 ohms
  • Voice Coil Inductance (Le)1.45 mH
  • Mechanical Q (Qms)7.28
  • Electromagnetic Q (Qes)0.51
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)2.4 ft.³
  • Mechanical Compliance of Suspension (Cms)0.19 mm/N
  • BL Product (BL)14.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)51g
  • Maximum Linear Excursion (Xmax)4.8 mm
  • Surface Area of Cone (Sd)506.7 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.03"
  • Baffle Cutout Diameter10.95"
  • Depth5.35"
  • # Mounting Holes8
  • Sealed Volume1.27 ft.³
  • Sealed F385 Hz
  • Vented Volume3.43 ft.³
  • Vented F342 Hz
  • BrandEminence Speaker
  • ModelDelta-12LFA
  • Part Number290-416
  • UPC876358000241
    (11 Reviews)
  • Weight13.9 lbs.
View similar products to the Eminence Delta-12LFA 12" Low Frequency Driver
