Eminence Beta-6A 6-1/2" High Power Midbass Midrange Woofer Speaker
Brand:|Model: Beta-6A|Part # 290-662
Eminence designed the Beta-6A as high output, high power handling 6-1/2" midbass/midrange that is well suited for use in concert-grade live sound applications or extreme SPL car audio applications.
$59.99
Part # 290-662
  • The Alpha-6 series midbass woofer evolved
  • 2" diameter voice coil for high power handling
  • Over 4 mm of Xmax in addition to high sensitivity
  • Perfect for use in multi-way, concert-grade loudspeakers
  • Water-resistant coating for use outdoors and in cars
The Beta-6A 6-1/2" midbass/midrange from Eminence is the evolution of the vaunted Alpha-6 driver series. With the Beta-6A, Eminence has increased the voice coil from 1.5" to 2" for increased power handling, while a strong magnet and motor system keeps the sensitivity high.
In addition to a larger diameter voice coil, Xmax has been increased to 4.5 mm and allows for lower usable frequency response. Additionally, a vented pole piece allows heat to escape for reduced power compression. The paper cone and dust cap have been treated for water-resistance, which is perfect for when the Beta-6A is used outdoors for live sound and in high SPL car audio systems.
Eminence designed the Beta-6A to work well in small sealed or vented enclosures, and in infinite baffles too. See the Manuals/Resources section for Eminence's cabinet design recommendations.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)175 Watts
  • Power Handling (max)350 Watts
  • Impedance8 ohms
  • Frequency Response95 to 4,000 Hz
  • Sensitivity94 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight30 oz.
  • Resonant Frequency (Fs)123 Hz
  • DC Resistance (Re)5.18 ohms
  • Voice Coil Inductance (Le)0.43 mH
  • Mechanical Q (Qms)3.46
  • Electromagnetic Q (Qes)0.66
  • Total Q (Qts)0.56
  • Compliance Equivalent Volume (Vas)0.12 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • BL Product (BL)8.13 Tm
  • Diaphragm Mass Inc. Airload (Mms)11g
  • Maximum Linear Excursion (Xmax)4.50 mm
  • Surface Area of Cone (Sd)129.9 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.59"
  • Baffle Cutout Diameter5.65"
  • Depth2.66"
  • # Mounting Holes4
  • BrandEminence Speaker
  • ModelBeta-6A
  • Part Number290-662
  • UPC876358002115
    (3 Reviews)
  • Weight6.25 lbs.
View similar products to the Eminence Beta-6A 6-1/2" High Power Midbass Midrange Woofer Speaker
