Eminence Basslite S2010 Neo 10" Bass Guitar Speaker
Brand:| Model: Basslite S2010
Recommended for bass guitar. Ideal in 1x, 2x, and 4x10 enclosures. Features a pressed steel basket, paper cone with cloth cone edge, and solid composition felt dust cap.
  • Neodymium magnet for lightweight performance
  • Copper voice coil on Polyimide former
  • Non-vented core
  • Pressed steel basket
  • Paper cone with cloth cone edge
  • Solid composition felt dust cap
290-517
Weight: 4.6 lbs.
IN STOCK
$99.99
Part # 290-517
Specifications: • Power handling: 150 watts RMS • VCdia: 2" • Le: 0.47 mH • Impedance: 8 ohms • Re: 5.02 ohms • Frequency range: 54-4,000 Hz • Magnet weight: 4 oz. • Fs: 46 Hz • Sensitivity: 96.2 dB 1W/1m • Vas: 2.2 cu. ft. • Qms: 4.16 • Qes: 0.34 • Qts: 0.31 • Xmax: 4.0 mm • Dimensions: Overall diameter: 10.08", Cutout diameter: 9.05", Depth: 4.25".
  • TypeBass Guitar
  • Nominal Diameter10"
  • Impedance8 ohms
  • Power Handling (RMS)150 Watts
  • Magnet MaterialNeodymium
  • BrandEminence Speaker
  • ModelBasslite S2010
  • Part Number290-517
  • UPC876358000449
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (5 Reviews)
  • Weight4.6 lbs.
View similar products to the Eminence Basslite S2010 Neo 10" Bass Guitar Speaker
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Basslite S2010 Neo 10" Bass Guitar Speaker is rated 4.6 out of 5 by 5.
Rated 4 out of 5 by from Good speaker for bassUsed this speaker in a cab as a small practice rig for my 4 and 5 string bass, good sound and seems to be well made.
Date published: 2011-03-10
Rated 5 out of 5 by from Replaced drivers in Peavey 210TVX CabinetI replaced blown drivers in a Peavey 210TVX cabinet with these drivers. It sounds great. I replaced my high frequency speaker cabinet in a bi-amped bass rig with this cabinet and use it every day. I love the sound. Its much lighter now too. I'm waiting for the sub to blow, I've got my eye on a replacement driver from Eminence.
Date published: 2011-02-17
Rated 5 out of 5 by from Super light, sound great.I loaded these into an Avatar B410 cabinet. I replaced the old Kappa ceramic speakers. It's a much lighter cab now, and it sounds just as good, if not better, than the old Kappas. It's a bit tighter sounding, actually, and the cab still has great lows. I was worried about the tuning of the cab when I first ordered these, but no worries. The cab sounds excellent still.
Rated 5 out of 5 by from Just plain awesome.....I purchased 2 of these to use in a 2 x 10 cab over a single 15 cab for my carvin bass amp (1000 watts total power) and they responed great. I Used them as a mid to high in a biamp setup. The 15 I used was the neo 15 for bass and together I had the best sound I could ever expect.
Date published: 2012-08-06
Rated 4 out of 5 by from Another "Bass" speaker that works great for guitarIf you need to replace the Tens in your old Bass-man or Super-Reverb, try these puppies. They are called "bass speakers," but they sound gorgeous for guitar, especially in old tube amps.Bass speakers generally have a lower resonant frequency than the lowest fundamental note on a guitar, which is approximately 80 Hz.That means if you use low alternate-tunings or want clear well-defined low-notes, bass speakers should work better than "guitar speakers." Although that is not always true, this particular model has the frequency response that accentuates the good and minimizes some bad frequencies of electric guitar. It also has a more even response, though nowhere near flat. This driver is sensitive throughout a broad range that is well-suited to electric guitar. That translates to a more controllable tone and volume throughout various playing ranges and styles. High sensitivity also means your amp does not have to work as hard, which can be good if you want clean, non-distorted tones. Metal-heads may want to try something else.
Date published: 2013-05-25
It says "Ideal in 1x, 2x, and 4x10 enclosures," is there any reason these wouldn't work in an 8x10 enclosure?
Asked by: Tomasan
NO. Go for it!
Answered by: Fanden
Date published: 2012-04-04
Customer projects that include: Eminence Basslite S2010 Neo 10" Bass Guitar Speaker
