Eminence APT-80 Super Tweeter with 80 degree Conical Horn
Brand:|Model: APT-80|Part # 290-532
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling and controlled low frequency behavior are assured.
OUT OF STOCK
Awaiting Updated Due Date
List Price$34.99
You Save29%
$24.99
Part # 290-532
  • Smooth response from 3,500 to 20,000 Hz
  • Phenolic diaphragm delivers detailed and accurate sound
  • 80 degree conical dispersion minimizes unwanted reflections
  • Recommended for use with 3,500 Hz or higher crossover
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling, controlled low frequency behavior and long-term reliability are assured. The APT-80 super tweeter is pre-mounted on an 80° conical horn.
Specifications: • Power handling: 45 watts RMS (crossover frequency 3.5 kHz, 18 dB/octave), 85 watts RMS (crossover frequency 5 kHz, 18 dB/octave) • Impedance: 8 ohms • Useable range: 3,500-20,000 Hz • Fs: 2,500 Hz • Recommended crossover: 3,500 Hz • SPL: 102.3 dB 1W/1m • Mfg. #APT-80 • Dimensions: 3-7/16" H x 3-7/16" W x 3-5/8" D • Cutout dimensions: 3-1/8" diameter.
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)45 Watts
  • BrandEminence Speaker
  • ModelAPT-80
  • Part Number290-532
  • UPC876358001323
  • Product CategoryHorn Loaded Bullet Tweeters
    (17 Reviews)
  • Weight1.6 lbs.
View similar products to the Eminence APT-80 Super Tweeter with 80 degree Conical Horn
in the Horn Loaded Bullet Tweeters product category.
Eminence APT-80 Super Tweeter with 80 degree Conical Horn is rated 4.6471 out of 5 by 17.
Rated 5 out of 5 by from Excellent tweeter for the priceI used this to replace the two tweeters in an old set of Cerwin Vega H15's. They are the exact same size and screwed right in place old the old ones. Just using a single APT-80 sounds 100% better than the twin CV tweeters. I had to make a square cover plate to cover the 2nd tweeter hole.
Date published: 2014-02-21
Rated 2 out of 5 by from Not a replacement for itself!Bought one of these to replace the exact same model, and guess what? It didn't fit. It was an Orange 4x10 bass cab. Really, really stupid in my opinion to switch sizes on people. Only buy these for new builds, can't say the original lasted all that long in the Orange either. Come on guys.
Date published: 2013-09-18
Rated 5 out of 5 by from Excellent tweeterThis was used with an Eminence woofer for building an extension speaker for a Strawberry Blonde amp. I believe it was speced in the original, no longer manufactured extension speaker. Excellent sound reproduction.
Date published: 2012-06-23
Rated 5 out of 5 by from Tight, Clean, SharpAn excellent bullet tweeter at a good price: This one of 4 Eminence tweeters I'm using between 2 pair of speakers on 2 different systems. With another brand, I've heard hiss and a scratchiness in some types of instrumentation, but these tweeters are tight and give you nothing but the sound that your system is producing itself. I've used these for approx. 3 years and recently had to replace one when my amplifier went nuts. This is a no-regret speaker.
Date published: 2012-02-08
Rated 5 out of 5 by from SweetRecently scored a vintage British made pre-Kaman Trace Elliot 1048 bass cabinet. Ther were 2 flavours, the other being the 1048H as in, err, HORN. This brute of a cabinet is loaded with celestions, ridiculously heavy by todays standards, but will knock china off your neighbour's walls. For a hoot, I lit a kitchen match in front of the port and hit a lo b and it blew it out with ease. I wanted a bit more hi-end articulation, so I added this tweeter in the stock spot (right in the centre, had to relocate the baffle brace but no biggie- angle irons and wood glue did the trick) with the Eminence PXB3K5 High Pass Crossover Board. I didnt use an L pad as I always set those at "flat" anyway and control the tone with the bass head. I find this tweeter to be an excellent addition to this cabinet. Its not overpowering, shrill, or nasal sounding AT ALL. Blends with the "middy" 10's rather bully. Not as "open" as a soft dome, and somewhat directional, but ITS A HORN. The stock OEM FOSTEX tweeter was close to $100 without a crossover so I figured how could i go wrong? For a $60 upgrade this was a VERY worthwhile upgrade and I couldnt be more pleased. One caveat: The cutout hole specified is 7cm #2.75 in# and the magnet fit through the hole, but some ribs on the back of the horn mounting flange wouldnt let it sit flush. 2 minutes with a dremel took care of THAT.
Date published: 2012-02-05
Rated 5 out of 5 by from .Very nice productJust as advertised, thanks so much Got it in the mail on timeso I could install product.
Date published: 2011-09-21
  • 2016-02-12T06:17CST
  • co_hasreviews, tv_0, tr_17
  • loc_en_US, sid_290-532, PRD, sort_mostRecent
What is the sensitivity?
Asked by: DEMjr
These have a sensitivity of 105 dB, 1w/1M.
Date published: 2014-11-10
Is the polar response curve for this tweeter available anywhere? - thanks
Asked by: rdiakur
Unfortunately we do not have one, although Eminence may have this information if you were to contact them directly.
Date published: 2014-07-08
Would this be a good replacement for an Ampeg 4x10HE. Any other advice for a replacement for this cab?
Asked by: Peghead
It should be a good option in terms of sound. I do not have any dimensions on what Ampeg used in this application though. It would be best to doublecheck the hole in the box and horn size but if they fit, it should do well.
Answered by: Chrisf
I need to replace the super tweeter on a SWR California Blond.  Would this speaker work for this application?  Would I need to replace the crossover also?
Asked by: acechandle
This depends on a lot of things. The tweeter will likely require cabinet mods in order to fit properly regardless. If the original was a standard horn type tweeter with a crossover, this will probably work fine with only a few cabinet mods. If the original was a piezo type tweeter, this will require a high pass filter for protection from low frequencies.
Would the APT-80 be a good choice for a bass speaker cab ?  I am building a (2) x 10" cab…..2 Eminence B 102's (8) ohm in para.  Thank you.
Asked by: Jim470
Yes this would be a good choice for a bass cab application.
  • 2016-02-12T06:57CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_290-532, PRD, sort_recentQuestionsFirst
