Electronic Solder 60/40 1.3mm (0.050") Diameter 1 lb. Spool
Brand:|Part # 370-034
High quality solder for electronic and electrical work. 60% tin and 40% lead with flux in the core for a strong, long lasting bond. Diameter: .050". 1 lb. spool.
List Price$35.99
You Save35%
$23.49
Buy 4-19 $19.50
Buy 20+$18.80
Part # 370-034
  • 60% tin and 40% lead with flux in the core
  • Solder for electronic and electrical work
  • BrandParts Express
  • Part Number370-034
  • UPC844632015557
  • Product CategorySolder
    (10 Reviews)
  • Weight1 lbs.
View similar products to the Electronic Solder 60/40 1.3mm (0.050") Diameter 1 lb. Spool
in the Solder product category.
Electronic Solder 60/40 1.3mm (0.050") Diameter 1 lb. Spool is rated 4.3 out of 5 by 10.
Rated 5 out of 5 by from Great solder Works fantasticI bought some Kaisi solder from China. Was not happy with this solder. Too small .3MM and cold solder joints often. Too small and flimsy to use. I bought a roll of this stuff and it works great for restoring vintage stereos (Pc boards). Very happy with this would buy again..
Date published: 2015-08-13
Rated 5 out of 5 by from Good SolderI been in the electronic's repair now for over 40 years, I find this solder to be just as good as the rest. I would not hesitate to buy this again.
Date published: 2015-03-11
Rated 4 out of 5 by from It's solder.I bought this to connect together electrical components and wires. It melts when touched to a hot lead and cools when heat is removed. All in all I think it works well. I do not use "Kester 44" because of the god awful smell so this is what I buy. Plus its cheap.
Date published: 2014-01-22
Rated 3 out of 5 by from Good Price but stiffer solderGood value but I will stick with Kester Solde next time.
Date published: 2009-05-01
Rated 5 out of 5 by from Excellent ProductThis is great for the bigger projects, flows very well. Highly recommend for the larger projects.
Date published: 2009-04-02
Rated 4 out of 5 by from Good thickness for vintage electronics workReasonable price for a pound, and a good thickness for vintage electronics. Might be too thick for newer pcb work where things are very tiny...Go for a smaller diameter for those applications...
Date published: 2008-06-26
  • 2016-02-06T06:30CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_370-034, PRD, sort_mostRecent
Difference in fluxes?
Is there a difference in the fluxes used in solder cores between brands, say between this one and the Kester?
Asked by: TShifrin
For general soldering this or the Kester brand perform equally well. Where you want to get very specific is when you are soldering boards with tight spaces, or doing audiophile components with silver solder.
Answered by: markajh
Date published: 2012-04-18
  • 2016-02-06T07:59CST
  • loc_en_US, sid_370-034, PRD, sort_recentQuestionsFirst
