182-578_ALT_0
182-578_ALT_1
Electroline EDA400 4-Port Low Noise CATV MINI Amp +7dB
Brand:|Model: EDA400|Part # 182-578
The ED400 four-port version is used in homes with a larger number of TVs or other devices requiring amplification. It provides 8.5 dB of gain on each port, which boosts signal levels on each device that is serviced by a dedicated port.
List Price$73.99
You Save21%
$58.18
Part # 182-578
  • Fully compatible with all digital and analog signal formats, forward and reverse
  • Noise factor of 3 dB
  • 6 kV surge protection on all outputs
  • Weatherproof housing
  • Sealed, 360º contact STCE-compliant F connectors
Frequently Bought Together
The EDA Mini series are the most compact versions in the Electroline offering. These compact versions offer the same performance and standards compliance as all other versions in the EDA family, which operators have consistently relied on since the first gallium arsenide (GaAs) chips were pioneered by Electroline. Fully compatible with all signal formats, both analog and digital, the EDA Mini series offers a low-noise figure (3 dB) and very flat amplification of the downstream, with a passive upstream. The optional power inserter provides greater flexibility when installing the EDA Mini and can result in configurations that may reduce the amount of coaxial cable required or offer a more discrete and aesthetic installation. Each home has a different set of devices and a different home wiring configuration. The ED400 four-port version is used in homes with a larger number of TVs or other devices requiring amplification. It provides 8.5 dB of gain on each port, which boosts signal levels on each device that is serviced by a dedicated port.
Features and Specifications: • Number of ports: 4 • Forward gain: 8.5 dB • Return path insertion loss: 8.2 dB • Forward passband: 54-1000 MHz • Return passband: 5-42 MHz • Frequency response flatness: ±0.8 dB • Noise figure: 3 dB • RFI isolation: 100 dB minimum • Surge protection: 6 kV (RF ports and wall adapter) • Operating temperature: -40°F to 140°F (-40°C to +60°C).
  • BrandElectroline
  • ModelEDA400
  • Part Number182-578
  • UPC853016001246
  • Product CategoryRF Distribution / Amplifiers
  • Weight1.25 lbs.
View similar products to the Electroline EDA400 4-Port Low Noise CATV MINI Amp +7dB
in the RF Distribution / Amplifiers product category.
