Electroline EDA-FT 08300 8-port RF/CATV Dist. Amp w/Return
Brand:|Model: EDAFT08300|Part # 182-568
The EDA-FT 08300 Flat-Top amplifier is designed to amplify an incoming analog or digital off-air signal, as well as CATV signal by 3 dB over 8 ports; 0 dB return loss means that each room of a house can use interactive CATV programs.
Comparable Items In Stock:
Part # 182-568
  • Shallow 2" mounting depth, 0 dB return path loss
  • Waterproof housing and SCTE compliant 360° F-terminals
  • Rated at IEEE 6 kV 3 kA combination wave standard
  • Short-circuit protected wall adapter
  • 5-year manufacturer's warranty
With the trend of more single family houses being built, Electroline introduces the Flat-Top amplifier to meet the expectation of having cable service in every room in the house. The EDA-FT 08300 Flat-Top is designed for large houses with a cable or off-air drop in every room. The flat top configuration keeps the wiring more compact and neater in both outdoor subscriber box or wall-mounted applications and eliminates the technical problems associated with trying to fit a standard 8 port amplifier into a box that is too small creating crushed and kinked cables that wreak havoc with digital services. Electroline Flat-Top amplifiers are the only amplifiers to offer a configuration with all F-connectors on the bottom edge of the amplifier, facing down. Also, Flat-Top amplifiers come with an active return path which makes managing return signal levels straightforward. With 0 dB of loss in the return path, interactive services can be deployed in any room without rewiring.
Features and Specifications: • Number of ports: 8 • Forward gain: 3 dB • Return path insertion loss: 0 dB • Forward passband: 54-1000 MHz • Return passband: 5-42 MHz • Frequency response flatness: ±1 dB • Surge protection (IEEE C62.41-1991, all ports) ring wave: 6 kV, 500 A, loc. B3, combination wave: 6 kV, 3 kA, loc. B3 • Operating temperature: -40°F to 140°F (-40°C to +60°C).
  • BrandElectroline
  • ModelEDAFT08300
  • Part Number182-568
  • UPC853016001833
  • Product CategoryRF Distribution / Amplifiers
    (5 Reviews)
  • Weight3.51 lbs.
View similar products to the Electroline EDA-FT 08300 8-port RF/CATV Dist. Amp w/Return
in the RF Distribution / Amplifiers product category.
