Electro-Voice ZXA1-100B-120V Amplified 8" 2-Way Speaker System Black
Brand:|Model: ZXA1-100B-120V|Part # 242-6400
As one would expect from Electro-Voice, the ZXA1 Series packs a serious big-stage punch. Electro-Voice drivers, components, and amplifiers are no less than legendary - all proven at the highest levels of live performance.
Part # 242-6400
  • 800W Class D lightweight amplifier
  • 100° x 100° coverage pattern
  • High output, 126 dB maximum SPL
  • Bi-Amplified design with 24dB/octave filter slope and transducer protection
The ZXA1 Series of loudspeakers wraps superior Electro-Voice technology in a durable yet lightweight cabinet, resulting in one of the most powerful and versatile compact powered loudspeaker systems available today.
The ZXA1-90 is designed for professional sound reinforcement applications that require maximum portability and minimum hassle. Fully integrated with carefully matched electronics and transducers, this line of products makes it quick and easy to set up a high quality sound system with an absolute minimum of cables and extraneous components.
The ZXA1-90 utilizes the EV8L, a high output, low distortion 8 inch woofer. The woofer is paired with the DH2005, a titanium diaphragm true compression driver. The compression driver is coupled to a 100° x 100° waveguide for smooth response to 20kHz and excellent dispersion control.
The ZXA1-90 loudspeaker is powered by an integrated 800W bi-amp module. The bi-amplified design features steep crossover slopes and woofer excursion protection for maximum output and reliability. The amplifier has a dedicated XLR microphone input with independent gain control, and a combo XLR/TRS line level input for an outboard mixer, instrument, or auxiliary device like your MP3 player, computer, or what have you. There is also an XLR line level output for daisy chaining ZXA1-90 units together or adding a subwoofer. A defeatable 100Hz high-pass filter facilitates seamless integration with the subwoofer.
The ZXA1-90 injection molded enclosure is made from high impact ABS for durability and light weight. The handle pocket and pole mount make the ZXA1-90 ideal for many portable applications. The ZXA1-90 enclosure also features a built in 45° monitor angle for floor monitor applications. The bottom of the ZXA1-90 features four (4) #8–32 suspension points for permanent installation.
Frequency response:
60 Hz to 20 kHz (-3 dB)
Frequency response:
48 Hz to 20 kHz (-10 dB)
Recommended high pass:
40 Hz
Maximum calculated SPL:
126 dB
Coverage pattern:
100° x 100°
Rated system power:
800 watts
Connectors:
1 XLR mic input; 1 XLR/TRS combo; 1 XLR output
Dimensions:
17.99" x 11.10" x 10.39"
Weight:
19.0 lbs. (8.6 kg)
  • Speaker TypeActive / Powered
  • Woofer Size8"
  • BrandElectro-Voice
  • ModelZXA1-100B-120V
  • Part Number242-6400
  • UPC701001106714
  • Weight22.7 lbs.
View similar products to the Electro-Voice ZXA1-100B-120V Amplified 8" 2-Way Speaker System Black
