Electro-Voice ZX1i-100W 8" 200W 2-Way Weatherized Speaker System White
Brand:|Model: ZX1I-100W|Part # 242-6390
The Electro-Voice® ZX1 is the new standard of no compromise audio performance and versatility for compact sound reinforcement.
Ships in 7-10 Business Days
Part # 242-6390
  • Indoor/Outdoor design - meets IEC 529, IP44 & MIL810 environmental specs
  • 100° x 100° coverage pattern
  • 200W Continuous, 800W peak power handling
  • High sensitivity, 121 dB maximum SPL
  • Integrated QuickSAM™ heavy-duty Strong-Arm mounting bracket included
Frequently Bought Together
Electro-Voice's new high-tech enclosure uses injection-molded high-impact polypropylene to make the ZX1i extremely durable. The enclosure geometry has been engineered to provide maximum rigidity and acoustic performance. The velocity compensated port design overcomes the limitation of many small cabinet loudspeakers and enables exceptional low-frequency response without vent noise.
ZX1i installation is incredibly simple with the included QuickSAM™ mounting system. The QuickSAM™ is a unique integrated mounting bracket which is virtually foolproof. It allows the installer to simply snap the speaker onto the bracket, and then tighten it to the desired position. For array mounting, there is an optional array bracket kit available which allows multiple units to be mounted together for a variety of configurations.
Two coverage patterns are available; 90° x 50° coverage (ZX1i-90) for longer throw and cluster applications, 100° x 100° coverage (ZX1i-100) for the broad and even dispersion needed in many distributed audio applications. An added benefit is horn rotation, allowing the ZX1i to be oriented either horizontally or vertically for complete coverage flexibility.
The ZX1i molded polymer enclosure is inherently water resistant. The addition of a multilayer grille with hydrophobic cloth and weatherized components enable the ZX1i to perform under many harsh environmental conditions. An optional weatherized input panel cover with a gland nut is available for additional protection.
The ZX1i’s long excursion, high output 8" woofer with a weatherized treated cone delivers smooth low-frequency performance with exceptional reliability. A sophisticated crossover network integrates it with the DH2005, a 1.25” voice coil true compression driver for maximum output with extended frequency response. Full bandwidth overload protection is provided for reliable, long term operation without adverse audible side effects.
Frequency response:
60 Hz to 20 kHz (-3 dB)
Frequency response:
48 Hz to 20 kHz (-10 dB)
Recommended high pass:
40 Hz
Axial Sensitivity:
92 dB (1w/1m)
Maximum calculated SPL:
121 dB
Coverage pattern:
100° x 100°
Rated system power:
200W continuous, 400W program, 800W peak
8 ohms nominal, 6 ohms minimum
4-Pin Phoenix Style
17.75" x 11.12" x 10.35"
18.5 lbs. (8.4 kg)
  • Woofer Size8"
  • BrandElectro-Voice
  • ModelZX1I-100W
  • Part Number242-6390
  • UPC800549417617
  • Weight25 lbs.
View similar products to the Electro-Voice ZX1i-100W 8" 200W 2-Way Weatherized Speaker System White
