Electro-Voice ZX1i-100TW 8" 2-Way Weatherized Speaker System White
Brand:|Model: ZX1I-100TW|Part # 242-6394
The Electro-Voice® ZX1 is the new standard of no compromise audio performance and versatility for compact sound reinforcement.
ORDER TODAY
Ships in 7-10 Business Days
$635.00
Part # 242-6394
  • Indoor/Outdoor design - meets IEC 529, IP44 & MIL810 environmental specs
  • 100° x 100° coverage pattern
  • 70V and 100V constant voltage taps, 8 ohm bypass
  • High sensitivity, 121 dB maximum SPL
  • Integrated QuickSAM™ heavy-duty Strong-Arm mounting bracket included
Electro-Voice's new high-tech enclosure uses injection-molded high-impact polypropylene to make the ZX1i extremely durable. The enclosure geometry has been engineered to provide maximum rigidity and acoustic performance. The velocity compensated port design overcomes the limitation of many small cabinet loudspeakers and enables exceptional low-frequency response without vent noise.
ZX1i installation is incredibly simple with the included QuickSAM™ mounting system. The QuickSAM™ is a unique integrated mounting bracket which is virtually foolproof. It allows the installer to simply snap the speaker onto the bracket, and then tighten it to the desired position. For array mounting, there is an optional array bracket kit available which allows multiple units to be mounted together for a variety of configurations.
The transformer version of the Zx1i (designated with a "T" in the model number) utilizes a special circuit such that when in transformer mode, the network re-configures itself to a current-actuated high-pass filter at the transformer primary. It gently rolls off the lowest frequencies to maintain a safe load on the amplifier without affecting the higher (vocal) frequencies and the program continues without interruption. Low frequency current is limited through the transformer, virtually eliminating low frequency saturation. Automatic Saturation Compensation allows many speakers to be run on a distributed line with a 50Hz high-pass filter before the amplifier, regardless of the number of speakers on the same line (the total tapped wattage should never exceed the amplifier's rating). With the same 50Hz high-pass, 10 speakers on transformers will produce the same full sound as a single speaker at 8 ohms.
Two coverage patterns are available; 90° x 50° coverage (ZX1i-90) for longer throw and cluster applications, 100° x 100° coverage (ZX1i-100) for the broad and even dispersion needed in many distributed audio applications. An added benefit is horn rotation, allowing the ZX1i to be oriented either horizontally or vertically for complete coverage flexibility.
The ZX1i molded polymer enclosure is inherently water resistant. The addition of a multilayer grille with hydrophobic cloth and weatherized components enable the ZX1i to perform under many harsh environmental conditions. An optional weatherized input panel cover with a gland nut is available for additional protection.
The ZX1i’s long excursion, high output 8" woofer with a weatherized treated cone delivers smooth low-frequency performance with exceptional reliability. A sophisticated crossover network integrates it with the DH2005, a 1.25” voice coil true compression driver for maximum output with extended frequency response. Full bandwidth overload protection is provided for reliable, long term operation without adverse audible side effects.
Frequency response:
60 Hz to 20 kHz (-3 dB)
Frequency response:
48 Hz to 20 kHz (-10 dB)
Recommended high pass:
40 Hz
Axial Sensitivity:
92 dB (1w/1m)
Maximum calculated SPL:
121 dB
Coverage pattern:
100° x 100°
Rated system power:
200W continuous, 400W program, 800W peak
Wattage Taps:
70V – 6W, 12.5W, 25W, 50W, 100W, 8 Ohm bypass
100V - 12.5W, 25W, 50W, 100W, 8 Ohm bypass
Connectors:
4-Pin Phoenix Style
Dimensions:
17.75" x 11.12" x 10.35"
Weight:
23.0 lbs. (10.4 kg)
  • Input Rating8 ohm,70V,100V
  • Special FeaturesIndoor / Outdoor,Water Resistant
  • Woofer Diameter8"
  • Configuration2-way
  • ColorWhite
  • BrandElectro-Voice
  • ModelZX1I-100TW
  • Part Number242-6394
  • UPC800549417631
  • Weight29 lbs.
View similar products to the Electro-Voice ZX1i-100TW 8" 2-Way Weatherized Speaker System White
