Electro-Voice ZX1-90 8" 200W 2-Way Speaker System Black
Brand:|Model: ZX1-90|Part # 242-6380
The Electro-Voice® ZX1 is the new standard of no compromise audio performance and versatility for compact sound reinforcement.
ORDER TODAY
Ships in 7-10 Business Days
List Price$419.00
You Save21%
$329.00
Part # 242-6380
  • Extremely smooth, wide frequency response
  • 90° x 50° coverage pattern
  • Rotatable horn lens design
  • 200W Continuous, 800W peak power handling
  • High sensitivity, 123 dB maximum SPL
  • Attractive, clean design with full grille
The ZX1's high-tech enclosure uses injection-molded high-impact polypropylene to make the ZX1 extremely durable. The enclosure geometry has been engineered to provide maximum rigidity and acoustic performance. The velocity compensated port design overcomes the limitation of many small loudspeakers and enables exceptional low frequency response without vent noise.
The ZX1’s long excursion, high output 8" woofer with a weatherized treated cone delivers smooth low frequency performance with exceptional reliability. A sophisticated crossover network integrates it with the DH2005, a 1.25” voice coil titanium diaphragm true compression driver for maximum output with extended frequency response. Full-bandwidth overload protection is provided for reliable, long term operation without audible effect.
The horn features 90° x 50° coverage with the important added benefit of rotation, allowing the ZX1 to be oriented either horizontally or vertically for the ultimate in coverage flexibility.
The ZX1’s molded polymer enclosure is inherently water resistant. The enclosure features an integrated pole mount, a pocket handle, and a wedge-angle design allowing for use as a stage monitor.
Frequency response:
60 Hz to 20 kHz (-3 dB)
Frequency response:
48 Hz to 20 kHz (-10 dB)
Recommended high pass:
40 Hz
Axial Sensitivity:
94 dB (1w/1m)
Maximum calculated SPL:
123 dB
Coverage pattern:
90° x 50° or 50° x 90°
Rated system power:
200W continuous, 400W program, 800W peak
Impedance:
8 ohms nominal, 6 ohms minimum
Connectors:
Neutrik NL4 Speakon (x2, parallel)
Dimensions:
17.98" x 11.12" x 10.38"
Weight:
18.5 lbs. (8.4 kg)
  • Woofer Size8"
  • BrandElectro-Voice
  • ModelZX1-90
  • Part Number242-6380
  • UPC800549682466
  • Weight23 lbs.
View similar products to the Electro-Voice ZX1-90 8" 200W 2-Way Speaker System Black
