Electro-Voice SX100+E 12" 200W 2-Way Speaker System Black
Brand:|Model: SX100-+E|Part # 242-6420
Through the extensive use of computer-aided design and modeling, Electro-Voice engineers have once again developed a state-of-the-art professional loudspeaker system: the SX100+E.
ORDER TODAY
Ships in 7-10 Business Days
List Price$635.00
You Save14%
$549.00
Part # 242-6420
  • Compact, ergonomic form factor
  • Ring-Mode Decoupling (RMD™)
  • Pure titanium compression driver
  • 65° x 65° constant coverage horn
  • High efficiency, high output
  • Molded-in pole mount, rigging points
The Electro-Voice® Sx100+E is a portable 200-watt constant-directivity speaker system featuring a highly efficient 12-inch two-way design. Its performance and physical design make it perfect for many applications requiring the highest quality sound, either portable or in fixed installations. The Sx100+E is excellent for live sound reinforcement, speech, pre-recorded program material, DJ, A/V, and institutional venues.
EV's exclusive Ring-Mode Decoupling™ enhances the outstanding performance even further by reducing resonance within the cabinet, making even the slightest tonal variations easy to distinguish. To produce their high SPL ratings, the cabinets feature cast-frame woofers with heavy ferrite magnets, and large-mouth horns molded into the enclosures that carefully direct all the power into the room, not at the walls.
The high-frequency section of the Sx100+E utilizes a molded 65° x 65° constant-directivity horn. This unique pattern contributes to high intelligibility; vocals sound natural yet “cut through,” even in reverberant or otherwise noisy rooms. Coverage pattern is uniform, and off-axis sound quality is very well maintained, even at 45° off axis (a 90° total coverage angle).
The horn’s unique Varipath™ throat geometry helps deliver output to the corners of the room, areas which are generally not addressed in the usual specifications of horizontal and vertical coverage angles. This results in more uniform coverage throughout, even to those parts of the audience that do not receive the strongest coverage.
The Sx100+E’s high-frequency horn is driven by the DH3, a wide bandwidth one-inch driver with a titanium diaphragm. EV's unique convex-drive TimePath™ phasing plug structure (U.S. Patent #4,525,604) provides extended high-frequency response which is exceptionally smooth and pleasing to the ear.
Frequency response:
60 Hz to 25 kHz (-10 dB)
Sensitivity:
98 dB (1w/1m)
Maximum calculated SPL:
127 dB
Coverage pattern:
65° x 65°
Rated system power:
200W continuous, 800W peak
Impedance:
8 ohms nominal, 5.6 ohms minimum
Connectors:
Neutrik Speakon
Dimensions:
23.1" x 16.9" x 12.3"
Weight:
32 lbs. (14.5 kg)
  • Woofer Size12"
  • BrandElectro-Voice
  • ModelSX100-+E
  • Part Number242-6420
  • UPC800549682305
  • Weight35 lbs.
View similar products to the Electro-Voice SX100+E 12" 200W 2-Way Speaker System Black
