Electro-Voice ETX-12P ETX 12" Two-Way Powered PA Loudspeaker
Brand:|Model: ETX-12P-US|Part # 245-5786
Electro-Voice has always been at the leading edge of pro audio, and now they've redefined powered PA technology. The ETX-12P may be considered the "Goldilocks" of the new ETX family: not too big, not too small, just right. And the sound...sweet mother of mercy, the sound. Guitars, vocals, anything with strong midrange will really shine with the 12" ETX.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$2,158.20
You Save44%
$1,199.00
Part # 245-5786
  • Tour grade construction - audiophile sound quality
  • SMX series 12" woofer, 1.25" titanium compression driver
  • Sublime acoustic signature for guitars, vocals; great mid-size performer for all-around applications
  • Angled side for use as an excellent floor monitor
The new ETX family of powered speakers builds upon the innovation and 85‑year heritage of Electro‑Voice audio engineering to offer the most advanced professional portable powered loudspeakers available today. The groundbreaking ETX Series is a versatile choice for live entertainment venues, rental companies, pro musicians and DJs, and installed sound.
The ETX family of powered speakers features three two‑way models (10", 12" and 15", all with a precision HF titanium compression driver), a three‑way model (15" with a 6.5" MF driver and a precision HF titanium compression driver) and two subwoofers (15" and 18" drivers). All models have an easy-to-use single-knob DSP which includes presets for multiple configurations and top+sub combinations. All ETX models are also designed for floor, stacked, or pole mounting (0 or 7.5 degrees) for portable use or permanent installation. The subs feature a dual-duty pole cup which is compatible with both 1-3/8" and M20 threaded poles.
Positioned above the ZLX and Live X families respectively, ETX powered loudspeakers complete a trio of recent EV portable loudspeaker offerings ‑ each of which was designed to bring best‑in‑class performance to its price point.
Inside each low‑profile, tour‑grade wood enclosure are a range of unique new features that set ETX Powered Loudspeakers apart, combining intelligent technology and innovative industrial design for spectacular results across all applications. EV‑engineered high‑efficiency transducers and high‑powered Class D amplifiers, Signal Synchronized Transducers (SST) waveguide design and smart FIR‑Drive DSP all work together to provide peerless EV sound quality and precise coverage at the highest SPLs.
Specifications: • Power rating: 2000 watts • Frequency response: 55 - 20,000 Hz (±3 dB); 43 - 20,000 Hz (±10 dB) • Maximum SPL: 135 dB • Coverage pattern: 90° x 60° • Enclosure: 18 mm, 13-ply birch plywood • Connectors: 2 XLR/TRS combo inputs; XLR link output • Suspension: 10 mm fly points x 8 • Power requirement: 100 ~ 240 VAC, 50 - 60 Hz • Dimensions: 24” x 15” x 16” (613 x 318 x 365 mm) • Weight: 52.0 lbs. (23.6 kg).
  • Speaker TypeActive / Powered
  • Woofer Size12"
  • BrandElectro-Voice
  • ModelETX-12P-US
  • Part Number245-5786
  • UPC800549738897
  • Weight61.0000 lbs.
View similar products to the Electro-Voice ETX-12P ETX 12" Two-Way Powered PA Loudspeaker
