Electro-Voice ELX215 Live X Dual 15" 2-Way Passive PA Loudspeaker
Brand:|Model: ELX215|Part # 245-572
This compact, powerful ELX215 Live X dual loudspeaker with real stage presence houses two EVS-15K, 15" woofers and a DH-1K, 1.5" titanium diaphragm compression driver.
List Price$1,048.00
You Save43%
ShippingTRUCK ONLY
$599.00
Part # 245-572
  • Great frequency response, no subs required
  • 600W continuous/2400W peak power handling
  • 96 dB SPL sensitivity; 137 dB max SPL
  • Rugged wood cabinet creates serious stage presence
Feel a real low end punch with this twin woofer configuration of the ELX215 Live X by Electro-Voice. This dual PA speaker is ideal for applications that demand high-volume output and an ultra-wide frequency response from a single cabinet with its two EVS-15K, 15" woofers and  DH-1K, 1.5" titanium diaphragm compression driver. Designed for house of worship, pro music, and other applications. A rugged wood cabinet creates serious stage presence.
Specifications: • Power handling: 600 watts continuous, 2,400 watts peak • Frequency range: 38 Hz – 20 kHz • Sensitivity: 96 dB • SPL: 137 dB max • Frequency response (-3 dB): 62 Hz - 18 kHz • Recommended high-pass frequency: 35 Hz • Max. SPL/1m (calc): 137 dB • Crossover frequency: 1.7 kHz • Nominal impedance (passive): 4 ohm • Minimum impedance: 3.7 ohm • Connector type: Dual NL4 • Grill: 18GA steel with black powdercoat • Cbinste material: 9-ply, 15 mm plywood, internally braced, with textured paint • Height: 45.43" H x 17.01" W x 19.72" D (1154 x 432 x 501 mm) • Weight net: 97.22 lbs. (44.1 kg). stacks with Live X subwoofers.
  • Woofer Size15"
  • BrandElectro-Voice
  • ModelELX215
  • Part Number245-572
  • UPC800549589567
  • Weight106 lbs.
View similar products to the Electro-Voice ELX215 Live X Dual 15" 2-Way Passive PA Loudspeaker
