Electro-Voice ELX115P Live X 15" 2-Way Powered PA Loudspeaker
Brand:|Model: ELX115P|Part # 245-575
Electro-Voice's ELX115P houses an EVS-15K 15" woofer, DH-1K 1.5" titanium diaphragm compression driver, and a 1,000 watt Class D amplifier.
Part # 245-575
  • Lightweight 1000W Class-D amplifier runs cool without fans
  • Easy setup and control with versatile input and output options
  • Rugged wood cabinet pole-mounts or stacks with Live X subwoofers
Electro-Voice's ELX115P 15" woofer is a powerful step up from the ELX112P, delivering extended lower frequencies and room-filling volume with an EVS-15K 15" woofer and DH-1K 1.5" titanium diaphragm compression driver. Designed for house of worship, pro music, and other applications the 1,000 watt Class D lightweight amplifier runs cool without fans. Housed in a rugged wood cabinet — pole mounts or stacks with Live X subwoofers. Easy to connect and control with versatile input and output options
Specifications: • Power output: 1,000 watts • Frequency range: 44 Hz – 20 kHz • SPL: 134 dB max • Frequency response (-3 dB): 56 Hz - 18 kHz • Frequency response (-10 dB): 44 Hz - 20 kHz • Max. SPL/1m (calc): 134 dB • Crossover frequency: 1.7 kHz • Connector type: 2 XLR/TRS combo jacks, 1 stereo RCA, and 1 XLR link output • Grill: 18GA steel with black powdercoat • Cabinet material: 9-ply, 15 mm plywood, internally braced, with textured paint • Dimensions: 27.87" H x 17.01" W x 15.04 D (708 x 432 x 382 mm) • Weight net: 53.57 lbs.  (24.3 kg).
  • Speaker TypeActive / Powered
  • Woofer Size15"
  • BrandElectro-Voice
  • ModelELX115P
  • Part Number245-575
  • UPC800549589512
    (2 Reviews)
  • Weight61.95 lbs.
View similar products to the Electro-Voice ELX115P Live X 15" 2-Way Powered PA Loudspeaker
