Electro-Harmonix 6V6 EH Vacuum Tube Duet Platinum Matched
Brand:|Model: 6V6 EH|Part # 072-842
Sweet, singing tone for high plate voltage amps. The 6V6EH combines a specially developed cathode coating, careful alignment of the grid, and tri-alloy plate material to create a rugged, wonderful-sounding 6V6 that performs flawlessly up to 475 volts.
$48.70
Buy 6+$44.77
Part # 072-842
Sweet, singing tone for high plate voltage amps. The 6V6EH combines a specially developed cathode coating, careful alignment of the grid, and tri-alloy plate material to create a rugged, wonderful-sounding 6V6 that performs flawlessly up to 475 volts. Perfect for high plate voltage amps like the Fender® Deluxe Reverb. Matching power tubes for equal current draw is important for maximum performance. Electro-Harmonix's platinum matching process consists of a 24 hour tube burn-in period followed by a bias (plate) current measurement in milliamps to ensure accurate matching.
PRODUCT SPECIFICATIONS
  • Tube TypePower Tubes
  • MatchingMatched Pair
  • BrandElectro-Harmonix
  • Model6V6 EH
  • Part Number072-842
  • UPC844632022227
  • Product CategoryVacuum Tubes
  • Weight0.4 lbs.
View similar products to the Electro-Harmonix 6V6 EH Vacuum Tube Duet Platinum Matched
in the Vacuum Tubes product category.
tube substitution
are there any substitutions for the 6v6?
Asked by: 4krow
That toob should be very easy to sub. The voltages are fairly low and the pin-out is completely standard. Some people have reported excellent results with a 6L6 substitution. The EL34/KT77 should also work. (check your operating point...) When browsing the available 8-pin pentodes, first check the pin-out. (being aware that different manufacturers use different letters to refer to the same thing; some mfgrs say "a" others say "P"). After that the only thing you really need to check are the maximum ratings. As long as you are within those ratings, you shouldn't have a problem. After that it is entirely up to your subjective tastes. -- you might have to re-bias or swap out the cathode resistor.
Answered by: AlonzoTG
Date published: 2011-07-13
  • 2016-02-06T08:43CST
  • loc_en_US, sid_072-842, PRD, sort_recentQuestionsFirst
