ECG HG-300D Mini Heat Gun
Brand:|Model: HG-300D|Part # 360-386
The ECG HG-300D Multi-function Mini Heat Gun features 2 speed/temperature settings and a built-in, self-supporting bracket making it ideal for hands-free heat shrink applications.
List Price$27.99
You Save29%
$19.88
Part # 360-386
  • 2 Speed/temperature settings featuring quiet operation
  • Comfortable and lightweight
  • Built-in bracket for self-support and table top use
  • Ideal for heat shrink tubing
  • Whisper quiet operation
  • +250° C (low) / +350° C (high)
  • safety shield on nozzle
The ECG HG-300D mini heat gun is the perfect accessory for heat shrink tubing applications. Its light weight comfortable design and built-in, self-supporting bracket make it fast and easy to use. The HG-300D features 2 speed/temperature settings and whisper quiet operation.
  • BrandECG
  • ModelHG-300D
  • Part Number360-386
  • UPC768249261544
  • Product CategoryHeat Guns & Torches
    (8 Reviews)
  • Weight0.813 lbs.
View similar products to the ECG HG-300D Mini Heat Gun
in the Heat Guns & Torches product category.
ECG HG-300D Mini Heat Gun is rated 4.875 out of 5 by 8.
Rated 5 out of 5 by from Excellent!This is what I've needed from the get-go. Forget the iron and lighter, this is the bomb.
Date published: 2015-05-27
Rated 5 out of 5 by from Mini heat gunI'm Building a custom amplifier, needed compact Heat gun to shirnk tubing. this unit works great! gets into smaller spaces.
Date published: 2014-06-12
Rated 5 out of 5 by from great for the pricethis may not be the worlds best heat gun but to honest for the price this product can and will do the job
Date published: 2013-03-24
Rated 5 out of 5 by from Powerful Little Heat GunGot this as a 'Deal of the Day' and am I happy I did!No more using lighters to shrink tubing. Never thought I'd like a small heat gun as much as this one. Sure, the cord is a little stiff brand new & the stand is a little small but, boy does it work great. Already have found many different uses for it. When this gun is on sale, buy one for yourself...
Date published: 2012-06-20
Rated 5 out of 5 by from Heat ShrinkerThis product is perfect for making professional looking heat shrink wraps on wire.
Date published: 2012-05-08
Rated 5 out of 5 by from Works greatI use it to shrink heat shrink tubing. For me it works better than my over kill heat gun. It heats up fast enough, gets hot enough and cools down fast.I'm glad I got it. I only wish it was a little smaller, it is bigger than it appears in the ad. No big deal though.I really do like it.
Date published: 2012-01-08
  • 2016-02-08T06:12CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_360-386, PRD, sort_mostRecent
Is it OK to use near a PCB?
On the high setting, it looks close to the solder's melting point? Even the low setting is close to some solders. Maybe I've confused C and F?I need to remove hot melt glue from a PCB. I thought I'd warm it up to make it pliable with this heat gun. There's too much, and too thick, to scrape away.
Asked by: rif314
This should work fine for the application as long as you don't heat one area for a long period of time.
Date published: 2013-02-18
Does this product can be used in 220 Volts ?
Asked by: Samuel
I will assume this device is UL listed, and since it appears to have a standard two conductor polarized cord it is not 220V compatible (it wouldn't even fit a 220 socket). Unless otherwise specified, most electrical equipment sold here is 110 Volts. The product description will normally indicate if a unit requires, or is compatible with, non-standard voltage. Call a Parts-Express sales rep if in doubt.
Answered by: squarewave
Date published: 2011-08-21
  • 2016-02-08T06:55CST
  • loc_en_US, sid_360-386, PRD, sort_recentQuestionsFirst
Videos
