EAW DN20/3003-8 2" Neodymium Compression Horn Driver 8 Ohm
Brand:|Model: DN20/3003-8|Part # 299-192
Save over half off the original retail price of this EAW compression driver, made by RCF, through this factory buyout!
Part # 299-192
  • Designed and manufactured in Italy for a top pro speaker builder
  • Powerful neodymium magnet system provides high motor strength
  • Titanium diaphragm offers excellent accuracy and durability
  • Unusually low crossover limit facilitates a wide range of design options
  • High power handling/low distortion Direct Drive voice coil assembly
  • Concert-level output and accuracy, yet 1/2 to 1/3 the weight of ceramic ferrite drivers
  • Included machined adapter allows compatibility with either 1.4" or 2" 4-bolt horns
This 2" exit high frequency compression driver was designed and built by RCF of Italy for use in EAW's (Eastern Acoustic Works) high-end KF755F and KF761 concert line array modules. The DN20/3003-8 (also referred to as the ND3020-T3) boasts several state-of-the-art technologies: a 3" diameter Direct Drive voice coil assembly that guarantees optimal energy transfer from the voice coil to the dome assembly (this creates extended frequency response beyond 10 kHz with reduced break-up modes and lowered distortion), and an ultra-thin pure titanium diaphragm with a variable, damped, progressive parabolic semi-circle surround. A high BL neodymium magnetic circuit provides increased and focused field strength in the voice coil gap.
Added to all of these features is a copper inductance ring to extend the usable response out to and beyond 20 kHz, an aluminum rear cover that features advanced vented fins for heat dissipation, a three-slot optimized geometry phase plug, and a machined adapter that allows this horn driver to mate up to 2"/4-bolt horns when used or 1.4"/4-bolt horns when removed.
Performance of this caliber doesn't come cheap, but you can save over 50% off the retail price through this factory buyout. Supplies are limited!
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)110 Watts
  • BrandFactory Buyouts
  • ModelDN20/3003-8
  • Part Number299-192
  • UPC848864002729
  • Product CategoryHorn Drivers
    (3 Reviews)
  • Weight7.4 lbs.
View similar products to the EAW DN20/3003-8 2" Neodymium Compression Horn Driver 8 Ohm
in the Horn Drivers product category.
