Latex Backed Speaker Cabinet Carpet Charcoal Yard 48" Wi
DuraLock Backed Speaker Cabinet Carpet Charcoal Yard 48" Wide
This carpet has a reinforced backing for durability and toughness, and is now more eco-friendly than ever with no latex. Perfect for applications such as stage monitor cabinets where the carpet will take a lot of abuse, it's also a great choice for automotive and other applications. Sold by the linear yard. 48" wide.
  • Industry standard covering for PA cabinets and more
  • Contains no latex, BPA or VOCs
  • Made from 100% post-consumer recycled poly fiber
  • Mold, mildew and stain resistant
260-764
Weight: 1.32 lbs.
IN STOCK
$9.80
Buy 10-49 $8.94
Buy 50-up$6.54
Part # 260-764
Qty:  YD
Due to consumer demand, Parts Express is now proud to offer latex-free and sustainably-sourced cabinet carpets. Our new formulation meets or exceeds the performance criteria of the original latex-backed product, but is much more environmentally responsible.
No latex or VOCs are used in this product; the fiber is made from 100% BPA-free polyester fiber sourced from recycled PET plastic drinking bottles. The fibers are locked together with a patent-pending DuraLock manufacturing process which creates a stiffer backing, and an extremely durable carpet that will not fray or unravel, and is also mold, mildew, and stain resistant. Made in the USA.
Note: Sold by the linear yard, 48" width. If you order one (1) yard (one unit), you will receive a piece of material 48" wide and 36" in length. If you order two yards, you will receive a piece 72" in length, three yards would be 108" long, and so forth.
  • BrandParts Express
  • Part Number260-764
  • UPC844632040634
  • Product CategoryCabinet Covering
  • Unit of MeasureYD
    (15 Reviews)
  • Weight1.32 lbs.
View similar products to the DuraLock Backed Speaker Cabinet Carpet Charcoal Yard 48" Wide
in the Cabinet Covering product category.
Latex Backed Speaker Cabinet Carpet Charcoal Yard 48" Wide is rated 4.8667 out of 5 by 15.
Rated 5 out of 5 by from Great stuffI've used this stuff for quite a while on many cabinets. Most recently, I've used it on my 1971 VW Beetle that I have been restoring. It makes a great carpet material for many of the car's surfaces at a much lower price than replacement carpet.On amps, it's nice because it stretches nicely, and is very resistive to wear and tear.
Date published: 2014-05-11
Rated 5 out of 5 by from Gracias JesusMan, I had been working on a box build for a customer and was getting close to my deadline, so I ordered a couple yards of this stuff on a Saturday and got it by Monday! Not even priority! Anyway, the carpet itself is very durable and strong, but it still has the flexibility to not make life heck for you (unlike other cheap carpets). But I slapped on some glue and BAM! I definitely plan on buying more in the future. Great product.
Date published: 2013-04-30
Rated 5 out of 5 by from Great Durable Cover FabricLove this fabric, been using it for years to cover speaker and rack equipment cabinets I make for myself. It bends around corners nicely and can even be stretched a bit, if need be, for a better fit. I have used carpet glue, and, more recently, spay adhesive to adhere it. Highly recommended for the "do it your self" person.
Date published: 2013-04-12
Rated 5 out of 5 by from Great carpet, worth the upgradeThis was used for my first carpet job on a sub box. It was easy to cut with a utility knife and seems durable. The latex backing is very thin and does a good job at only allowing minimal stretch without it pulling appart. I applied it with 3M 90 spay adhesive since people suggested the 70 doesn't hold up to heat. I'm happy with the product...I could have fit a few seams better but it was good enough for my trunk.
Date published: 2013-03-27
Rated 5 out of 5 by from firm backing, easy corners, better than othersThis is really great carpet! I've used many types of carpet over the years (mostly car audio) and this is without a doubt one of the best I've seen. If you are in doubt about the latex backing, it's not thick at all and easily rounds corners. The non latex backed carpet will not last to any type of everyday abuse. I use the 3M 90 adhesive (part #340-278) as the 3M 77 tends not to hold in high heat environments. Parts-Express shipped it to me in a roll all one cut (3yd X 48" Wide).
Date published: 2011-06-09
Rated 4 out of 5 by from Commercial GradeSame stuff you see on commercial PA cabinets. Well worth the cost to get something durable and easy to work with. To get the best results, make sure to use proper adhesive and take your time.
Date published: 2009-11-17
  • 2015-05-05T07:20CST
  • co_hasreviews, tv_0, tr_15
  • loc_en_US, sid_260-764, PRD, sort_mostRecent
If I order multiple QTY, is it packaged as one long piece of material?
I had to call customer service to confirm that (e.g. QTY:3) would be 3yd x 48" wide shipped as one long cut at 3yd x 48" and not three separate sections 1yd x 48".
Asked by: caudio
Yes, this product is sold by the linear yard, so a three yard piece would be 48" wide, and 108" in length.
Answered by: RussR
Date published: 2011-06-10
  • 2015-05-05T08:38CST
  • loc_en_US, sid_260-764, PRD, sort_recentQuestionsFirst
Customer projects that include: DuraLock Backed Speaker Cabinet Carpet Charcoal Yard 48" Wide
