Dual XPR510D Class-D Strappable Mono Mobile Audio Power Amplifier 1500W Max
Brand:|Model: XPR510D|Part # 267-5041
Get your subwoofer rocking with this Class-D mono amplifier from Dual! The XPR510D has advanced features not normally found at this price point, including a subsonic filter, variable bass boost, and the ability to strap two amplifiers together for up to 3,000 watts peak power output!
Part # 267-5041
  • 2 ohm stable Class D design
  • Strappable design for combining multiple amps to power a single subwoofer
  • Advanced features and includes remote volume control for bass
The Class D XPR510D is the largest mono car audio power amplifier available from Dual, and they pulled out all the stops building it. Not only is it 2 ohm stable, with a MOSFET pulse width modulated power supply to handle high current demands, it's built so solidly that you can combine two XPR510Ds together (also called strapping or amplifier bridging) to increase maximum output power from 1,500 to 3,000 watts RMS (into a two ohm load).
At this price point, you would be happy with just a plain amplifier without the extra features that Dual offers with the XPR510D: Extruded aluminum heatsink, easy-to-reach side mounted controls, auto-reset speaker short circuit protection, a variable 40 to 180 Hz low-pass crossover, variable bass boost, a variable 17 to 50 Hz subsonic filter (to protect ported subwoofers from frequencies below the port tuning frequency), a remote bass volume control module, and large power, ground, and speaker output terminals.
• Power output:
            750 watts x 1 @ 4Ω
            1,500 watts x 1 @ 2Ω
• Signal-to-noise ratio: 75 dBA (1 watt into 4Ω)
• Frequency response: 40-180 Hz
• Crossover:
            Low-pass (variable): 40~180 Hz
• Bass boost (variable): 0 to 12 dB, 30~80 Hz
• Subsonic filter: 17~50 Hz
• Dimensions (L x W x H): 11.06" x 10.55" x 2.76"
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)750 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandDual Electronics
  • ModelXPR510D
  • Part Number267-5041
  • UPC827204103326
  • Product CategoryCar Amplifiers
    (1 Reviews)
  • Weight7.65 lbs.
View similar products to the Dual XPR510D Class-D Strappable Mono Mobile Audio Power Amplifier 1500W Max
in the Car Amplifiers product category.
