Dual XPE1700 1000 Watt Mono Amplifier
Brand:|Model: XPE1700|Part # 267-5011
Dual's XPE1700 mono amplifier has 400 continuous watts of grunt on tap to drive power-hungry subwoofer loads.
Part # 267-5011
  • MOSFET PWM power supply
  • Variable bass boost: 0, 6, 12 dB
  • Selectable 35 Hz subsonic filter
  • 2-ohm stable
  • High and low level inputs
  • Bi-color LED status indicator
Dual's XPE Series amplifiers pack high-volume style and performance into a compact, black, crisply-designed brushed aluminum chassis. Intended primarily for mono subwoofer applications, the XPE1700 cranks out 400 watts continuously into a 2 ohm load, 1,000 watts peak.
Specifications: • Power output: 240 watts RMS x 1 (4 ohm), 400 watts RMS x 1 (2 ohm), 1,000 watts max x 1 • Total harmonic distortion (THD) + N: < 1% at rated output • Signal to noise ratio (S/N): > 75 dBA •Input sensitivity: 200 mV~ 6 V • Frequency response: 20-20,000 Hz • Dimensions: 8.95" L x 13.3" W x 2.06" D • One-year manufacturer's warranty.
Additional features:
•Low level RCA inputs
•High level speaker inputs
•Class A/B output design
•Extruded aluminum heat sink
•Barrier strip connection terminals
•Side mounted controls
•Auto-reset speaker short circuit protection
•Speaker short circuit protection
•Reverse polarity protection
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)240 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandDual Electronics
  • ModelXPE1700
  • Part Number267-5011
  • UPC827204103258
  • Product CategoryCar Amplifiers
  • Weight7.05 lbs.
View similar products to the Dual XPE1700 1000 Watt Mono Amplifier
in the Car Amplifiers product category.
