125-362_ALT_1
125-362_ALT_2
125-362_ALT_3
Dual-Port USB Car Charger Adapter for Apple iPhone iPad iPod & Android Devices
These days, it seems like everything takes USB power. This adapter charges up to two USB devices at once from a single 12V power port or cigarette lighter.
  • Input: 12 - 24 VDC Cigarette Lighter Socket
  • Dual Output: 1 Amp for iPhone and 2.1 Amp for iPad
  • Blue LED Power Indicator
  • Built-in short circuit, overvoltage, automatic overload protection
125-362
Weight: 0.05 lbs.
IN STOCK
List Price$8.99
You Save27%
$6.50
Buy 4-up$5.96
Part # 125-362
Cut the clutter! This USB car charger adapter lets you cut down on the number of charging accessories in your vehicle by charging two devices at one time through the two USB ports. The low current port is perfect for slow charging to maximize the life of your device's batteries. The high current port charger gets your device up and going quickly. Specifications: • Input voltage 12 VDC • Output voltage 5 VDC • Output current: 2.1 amps total.
  • DC Output Voltage5V
  • Current Capacity2100 mA
  • Center/Tip PolarityUSB Port(s)
  • Plug SizeUSB Port(s)
  • Input Voltage12 VDC VAC
  • BrandParts Express
  • Part Number125-362
  • UPC844632095702
  • Product CategorySmartphone, iPod & iPad Accessories
    (5 Reviews)
  • Weight0.05 lbs.
View similar products to the Dual-Port USB Car Charger Adapter for Apple iPhone iPad iPod & Android Devices
in the Smartphone, iPod & iPad Accessories product category.
Dual-Port USB Car Charger Adapter for Apple iPhone iPad iPod & Android Devices is rated 4.0 out of 5 by 5.
Rated 2 out of 5 by from Compact&InexpensiveOK, but doesn't stay plugged in. It needs something to increase friction in the socket.
Date published: 2014-02-10
Rated 3 out of 5 by from not for iPadI got this to charge my iPad, but when I plug it in I get a message that says, it is not an authorized apple product, and it does not charge.
Date published: 2014-01-28
Rated 5 out of 5 by from Wow...it actually puts out rated amperageAfter trying a couple "ebay specials" to get the required 2A required for fast charging my tablet in the car, I found one that actually works. I've tried it on a few smart phone, tablets, an even the two MiniDSPs in my car and all perform flawlessly and (in the case of the things with a battery) charge quickly and stay charged even while using bluetooth/gps/wireless. Highly recommended. As another review stated, the LED is quite bright, but it doesnt' bother me. For the tinkerers, the case can be opened easily without tools and the LED can be snipped out if you want to remove it. Of course this would probably void any returns, but I thought I should point it out.One quick note however: the first unit I received burned up almost immediately after I plugged it in. I believe this was caused by a loose spring that connects the center pin to the positive 12v terminal on the board. There's a small plastic "sheath" that keeps the spring centered and I think mine just came loose in transport. Christina with tech support was amazing and sent me a replacement immediately. I noticed on the new (and fully functional) one that the center pin moves easily, as where the defective one was almost stuck in place and wouldn't move without a little force.
Date published: 2013-12-28
Rated 5 out of 5 by from Great LITTLE 2-output adaptorThis is a very small adaptor that has output for 2 devices, one high-power for iPad. Inexpensive, too!!
Date published: 2013-05-18
Rated 5 out of 5 by from Works as advertisedBought this to charge my iPod in the car and my son's tablet when it needs it. I like the flexibility and power it produces. This will be great on vacations for back seat passengers who need to charge their handheld electronics. Best price and power I've seen so far. Only downside is the super bright red led. It's a little distracting while driving, when used up front. I am reluctant to leave it plugged in as it draws attention to the interior when parked. Otherwise, it's great.
Date published: 2013-03-18
can you use the dual port USB car charger adapter be used to charge 2 iphones at the same time, or is the higher powered one too high for an iphone?
Asked by: Mecmaine
This will charge two devices at the same time. The higher power output only means it has higher current draw capability for larger devices. Since the device only draws the current that it needs this will not be a problem.
Does anyone know where to find USB faceplates?
I want to buy a charger like this one and use it on a 12v boombox. However, I want to mount it on the wood panel, and I also want it to look presentable. Does anyone know where to locate a faceplate that would work with a dissected specimen of the above charger?
Asked by: FrontierKodiak
You have a couple options.Option 1:You could make a PCB with the USB connnectors on it with a 5volt regulator (PE# 7805) and perhaps PNP power transistor (PE#s TIP147 or NTE2344, etc) for more amperage. Then mount USB A connectors (PE#s 320-247, 320-248, 320-251). Then cut slits for the usb cable connection.Option 2:You could use this connector. Normally the car chargers are held together with a screw or two. Take out the screws, the face plate should come right off, then modify the case to fit your mounting needs. For example drill a hole in the wood that will fit this snugly. Insert and glue.Option 3:PE sells panel mount USB connectors(PE#s: 092-278, 092-279) usually meant for dishes(PE#s: 262-028, 262-334, 262-348, 262-838, etc). You could either use stand alone or buy dishes to give a pro audio feel to your boom box. Be aware that they are USB A (normal) to USB B (typically a printer type) connectors. PE also carries these cables (PE#s: 130-047, 139-080).Option 4:Look for a laser cutting service online. It is really awesome service. You find one of the many materials (Aluminum, Stainless Steel, Derlin, Acrylic, Styrene, Silicone, Melamine finished MDF, Plywoods, Veneer MDF, plain MDF, Bamboo, Hardboard, Cork, and Leather, Cardstock, Felt & Cardboard), pick a size, upload your design with cuts, mounting holes(vectors), and engraving(raster). They then make your design and send it to you for a reasonable price. Voilâ, you have your own custom USB face plate, or control panel.Option ∞Actually the options really are limitless. I have only touched on a few. Look all over the place for solutions. You might be surprised where and how you find ideas for control design.Best of luck☺
Answered by: JDoyner
Date published: 2013-06-20
Customer projects that include: Dual-Port USB Car Charger Adapter for Apple iPhone iPad iPod & Android Devices
