261-164_ALT_0
261-164_ALT_1
Dual Gang Reversible Bulk Cable Wall Plate White
Unique to this wall plate is a removable cable plate hood which may be installed on the outside of the wall for cable protection, or inside of the wall for use as a flush cable port that creates a custom hidden in-wall cable management system.
  • Unique two-piece wall plate design provides for easier installation
  • Removable and reversible hood design
  • Accommodates HDMI, DVI, VGA, and audio cables
  • Designed to fit standard electrical J-boxes
  • Perfect installation piece for plasma and LCD TVs
261-164
Weight: 0.15 lbs.
IN STOCK
List Price$8.99
You Save36%
$5.79
Buy 4-up$5.25
Part # 261-164
Bulk cable wall plates save installation time and money while providing a clean finished appearance. Unique to this wall plate is a removable cable plate hood which may be installed on the outside of the wall to provide maximum cable protection and to keep debris from falling into the wall. Alternatively for flat panel TV installations, where space between the wall and the TV is at a minimum, the cable hood may be mounted inside of the wall for use as a flush cable port that creates a custom hidden in-wall cable management system.
Note: A low voltage mounting bracket is needed to install this wall plate. See related items for the appropriate bracket.
PRODUCT SPECIFICATIONS
  • SizeDual Gang
  • FinishWhite
  • BrandParts Express
  • Part Number261-164
  • UPC741835079808
  • Product CategoryBulk Cable Wall Plates
    (8 Reviews)
  • Weight0.15 lbs.
View similar products to the Dual Gang Reversible Bulk Cable Wall Plate White
in the Bulk Cable Wall Plates product category.
Dual Gang Reversible Bulk Cable Wall Plate White is rated 4.5 out of 5 by 8.
Rated 5 out of 5 by from Great Wall PlateThe reversable nature of this is what makes it so great... and it's thick enough that you dont feel like you are going to snap it while you are changing it around... can fit a good amount of cables through it.... I have one with 3 hdmi, 2 power cords, 1 componet cable, 2 speaker wires, and a wii sensor cord... and there is room for more.
Date published: 2012-12-17
Rated 3 out of 5 by from good productthis is not quite what we were looking for but it served its purpose. I liked that I could find it here and that I could choose the color. I only wish it had an inverted cover.
Date published: 2010-02-10
Rated 4 out of 5 by from Good when you know you'll be changing your setupThe reversible nature of this allows it to be used behind a flat panel install, as well as a cleaner look behind a cabinet. This is perfect if you know you are going to be changing what cables you have running between your devices a lot. If you don't plan to change your setup though, I'd recommend the more cable specific wall plates. This unit leaves quite a large opening after the cables have been pulled thorough and could be drafty in colder climates.
Date published: 2009-12-16
Rated 4 out of 5 by from Good productI loved everything about this product, that served my needs of inputting 12 gauge wires for 7.1 system to the wall behind the TV. The only thins is that sides tende to bend up, thus not sitting tighta against the wall... That is a cosmetic issue, that you can see the crack. However, it is behind the TV, and not very easily noticeable...
Date published: 2008-12-09
Rated 5 out of 5 by from Very Good ProductBeing reversible make this a great product.
Date published: 2008-11-20
Rated 5 out of 5 by from like a pro-installervery easy to install good looking at a resonable price
Date published: 2008-08-27
  • 2015-02-25T07:41CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_261-164, PRD, sort_mostRecent
Part no. 261-164 (dual gang bulk cable wall plate) Can this simply be screwed onto a standard size two gang metal outlet box? Thanks, Steve
Asked by: Stephanh
Yes this will fit any standard dual gang box or mud ring.
Date published: 2014-09-09
  • 2015-02-25T08:43CST
  • loc_en_US, sid_261-164, PRD, sort_recentQuestionsFirst
Customer projects that include: Dual Gang Reversible Bulk Cable Wall Plate White
