090-471_ALT_0
090-471_ALT_1
Dual Banana Plug Black
Dual banana plugs are for use with test equipment including volt meters and multimeters, frequency generators and counters, and audio devices using banana jacks or binding posts with standard 0.75" center to center spacing.
090-471
Weight: 0.033 lbs.
IN STOCK
$2.25
Buy 10-99 $2.00
Buy 100-up$1.71
Part # 090-471
Dual banana plugs have been widely used in the electronics industry since early in the last century. Commonly used with test equipment, dual banana plugs are designed with industry standard 0.75" center to center post spacing. A plastic tag molded to one side of the connector is marked GND so the user can quickly identify the negative side of the connector. An integrated strain relief on one side of the connector holds the cable securely in place. Accepts up to 12 AWG cable and attaches with screw terminals so soldering is not necessary. Nickel plated brass contacts will provide a lifetime of use free of oxidation.
  • Style / TypeDual
  • Contact PlatingNickel
  • BrandParts Express
  • Part Number090-471
  • UPC844632011498
  • Product CategoryBanana Plugs
    (6 Reviews)
  • Weight0.033 lbs.
View similar products to the Dual Banana Plug Black
in the Banana Plugs product category.
Dual Banana Plug Black is rated 3.0 out of 5 by 6.
Rated 4 out of 5 by from Standard PlugIn response to Z - 16146's complaint about the spacing between the tips. The spacing on ALL dual banana plugs conforms to an industry standard designed for test equipment.It is the audio manufacturers who fail to conform to the standard spec. Every speaker or amp that has banana plug terminals seems to have different spacing. It might be nice if Parts Express noted this in the item description, but it's not the fault with the plug.I like this type because they're not as deep as others, and the wire comes in at a right angle. Since the spacing won't fit my speakers or receivers, I just cut them in half with a Dremel tool to make two separate plugs.I've gotten plugs of this design from other sources, and these do seem to be somewhat lighter duty. I'm sure they'll stand up to all the connecting and disconnecting I'll ever do at home, but if I was setting up and breaking down a pro PA every day I'd probably look for a sturdier version. Not that these are 'cheap' they're just don't seem 'heavy duty'. Anyway, I will these again for what I use them for.
Date published: 2013-09-11
Rated 3 out of 5 by from Not for Repeated UseThe plug worked well initially, but did not last long under repeated use. On two separate occasions the pin broke apart when removing from ampilfier.
Date published: 2011-03-07
Rated 2 out of 5 by from Just another plugIt worked
Date published: 2012-11-28
Rated 1 out of 5 by from Worst banana plugs ever- they fit on nothingThese are the worst banana plugs in the known universe- I don't know what type of crack those other 2 reviewers are smoking, but these plugs do not fit on any set of binding posts I have tried ( Sony speakers, Athena speakers, JL Audio 10w7 sealed enclosure, insignia speakers, Sony 7.1 receiver or Denon 7.1 receiver )- The distance between the plugs is a good half inch or more too short. I ordered 14 pairs, and they were repackaged and returned within 14 minutes. They fit on NOTHING! Maybe they might fit on the generic parts-express branded binding posts, do not expect them to fit on any pre-existing binding posts that you have. If they did fit however, they would have been awesome and the price is unbeatable. However, since that is not the case, stay far far away.
Rated 3 out of 5 by from Acceptable at a fair priceThis seems to be the standard of the industry unless to go to much better quality Monster connectors at a MUCH HIGHER PRICE. Still it's a bit flimsy for professional use in sound reinforcement. Probably more suited to home use.
Date published: 2011-02-17
Rated 5 out of 5 by from Works Great!These work so well that I will never buy the gold plated ones again. I'm using outdoor electrical cord as speaker wire and it fits perfectly in these units. Even put heat shrink over them to seal the connection.
Customer projects that include: Dual Banana Plug Black
