200-150_ALT_0
200-150_ALT_1
200-150_ALT_2
200-150_ALT_3
DIY Theatre White Platinum Projector Screen Paint Kit
This White Platinum Projector Screen Kit is a complete bundle for creating an economical, high-quality projection screen on an existing wall. The kit is ideal for home theaters, houses of worship, conference rooms, and sports bars.
  • Custom projection screen at an affordable price
  • Patented formulation
  • Create up to a 90 sq. ft. projection screen
  • Will not get sticky, wrinkle, or sag over time
200-150
Weight: 13 lbs.
IN STOCK
List Price$249.00
You Save22%
$194.00
Buy 2-up$188.00
Part # 200-150
Installing a projection screen can difficult be a difficult prospect, taking up valuable in-room space and adding a potentially overlooked expense to projector installation.
The White Platinum Projector Screen Kit is affordable, high-quality alternative to traditional projection screens. It allows you to create a large, high-contrast projection surface on an existing wall. The kit contains two surface treatments – a primer/sealer and no-mix polymer screen coating – along with the rollers necessary to apply them and easy to follow, comprehensive instructions for installing and optimizing your new projection screen.
The resultant screen can be up to 90 square feet and will have a fixed gain of 1.25. Why buy a projector screen when this patented surface will not get sticky, sag, or wrinkle?
DIY Theatre Screen Paint
Conference Room
DIY Screen Paint Confrence Room
Expensive electric screens will erode an A/V budget that you could be using to upgrade your digital equipment. Unlike traditional screens, you will find that the White Platinum Projection Screen Kit will offer you full control over the size and shape of the projection screen, so you can really customize your screen to fit with the rest of your conference room. Tailor your screen to the lighting conditions rather than modifying your room and lighting to accommodate the projector screen.
House of Worship
DIY Screen Paint House of Worship
More and more houses of worship are realizing the benefit of large AV projector screens to put new energy in their AV program. In many cases, worship audio-visual is a requirement due to congregation size and the need to broadcast to areas that can not see the service. Compared to traditional screen products, the White Platinum projector screen material makes any worship AV installation affordable.
Control Room
DIY Screen Paint Control Room
The White Platinum Projector Screen kit deploys in any size and any configuration, making it perfect for a command and control screen setup. In many cases, projection screens are a requirement due to command center size and the need to accommodate the multitude of screen displays required. Compared to traditional screen products, the kit makes the entire command and control center installation affordable. There are simply no other technologies that are large and adjustable enough to meet the size and configuration requirements of a command center.
  • BrandDIY Theatre LLC
  • Part Number200-150
  • UPC844662087982
  • Product CategoryProjector Screens & Paint
    (2 Reviews)
  • Weight13 lbs.
View similar products to the DIY Theatre White Platinum Projector Screen Paint Kit
in the Projector Screens & Paint product category.
DIY Theatre White Platinum Projector Screen Paint Kit is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Nice Projection SurfaceWe recently updated two of our ITV classrooms here at the college. In one room I have two lampless projectors side by side projecting onto the front wall of the classroom. Instead of hanging two screens we decided to paint the area with DIY Theatre White Platinum Projector Screen Paint. It was easy to apply and we are very happy with the results.
Date published: 2014-01-26
Rated 5 out of 5 by from Great Results - Easy to ApplyAll you need is a flat wall and a little patience. I had this done in less than 4 hours spread over two evenings. The kit comes with two really excellent roller covers. Started with 2 inch blue masking tape to mark off the screen area. You need to use extra masking so you can start and stop each stroke off the screen area. I used sandpaper to eliminate the little bumps and fuzz in the existing paint on the wall. The primer was easy to apply but had a sweet, almost obnoxious odor. I let it dry overnight and then applied the polymer top coat. Two coats of polymer applied about two hours apart. The polymer was easy to apply, no runs, no sags and no splatter. It really made the image "pop". This is a great product that really works as promised.
Date published: 2013-08-12
Customer projects that include: DIY Theatre White Platinum Projector Screen Paint Kit
