Diode/Transistor Tester Kit
Easy to build dynamic tester allows testing of diodes and transistors in circuit. Identifies NPN/PNP transistors and anode/cathode of diodes. Checks all types. Requires 9V battery, not included. Net weight: 1-1/4 lb.
320-074
Weight: 1.4124 lbs.
IN STOCK
Order Soon - Only 3 Left In Stock
$28.64
Part # 320-074
  • Project Kit TypeTesters & Problem Solvers
  • BrandParts Express
  • Part Number320-074
  • UPC756619000510
  • Product CategoryElectronic Project Kits
    (6 Reviews)
  • Weight1.4124 lbs.
View similar products to the Diode/Transistor Tester Kit
in the Electronic Project Kits product category.
Diode/Transistor Tester Kit is rated 3.5 out of 5 by 6.
Rated 4 out of 5 by from Pretty Good.It was fun to build. At first I wasn't sure whether it had any advantage over just using a multimeter to test transistors and diodes but once I tested a transistor with a multimeter and it gave me an acceptable beta value. When tested with this kit the transistor was bad. The transistor in fact wasn't working in the circuit. Perhaps the method this circuit uses is different from the way a multimeter tests HFE.It's useful for testing larger transistors that don't fit in multimeters.
Date published: 2011-08-14
Rated 1 out of 5 by from so-soa good multimeter can do everything this thing does.
Date published: 2009-12-06
Rated 1 out of 5 by from Price is HORRIBLE, This SHOULD be ON SALE @ $9.99Price is HORRIBLE, This SHOULD be ON SALE @ $9.99This is an OK piece, however if they don't lower the price I'm going to simply build my next ones without a kit from scratch, cloning the one I have already, probably cost me about $5.00 in parts!!!
Date published: 2009-09-11
Rated 5 out of 5 by from Kitting Still Is A Great IdeaNothing educates a user like the kit building experience. You learn the product inside and out and get a much better usually constructed end product. I still can't figure out how they can market this kit so cheaply with so many components and still make a profit.
Date published: 2008-03-19
Rated 5 out of 5 by from Great productEasy to use and easy to assemble. Good value.
Date published: 2008-02-04
Rated 5 out of 5 by from great product guick servicemakes it easy to find them npn & pnp & pin locations all so good for mathching. and more
Date published: 2007-12-15
II WANT TO MAKE A RAILGUN SO WILL THIS WORK IN CHARGING THE CAPACITORS?
Asked by: railgunman123
This is a transistor tester, unfortunately this will not charge capacitors.
Date published: 2013-01-10
Customer projects that include: Diode/Transistor Tester Kit
Manuals / Resources
Related Products
Customers Also Bought
2N3904 Transistor
Part # 2N3904
2N4401 Transistor
Part # 2N4401
