390-735_ALT_0
390-735_ALT_1
390-735_ALT_2
Digital Handheld Capacitance Meter
Brand:|Part # 390-735
Hand held capacitance meter features 3-1/2 digit display, 0.1pF to 20,000uF in 9 ranges, zero adjustment of +/- 20pF to compensate for parasitic capacitance in test leads, and is fully protected from a charged capacitor.
List Price$99.99
You Save55%
$44.65
Part # 390-735
Hand held capacitance meter features 3-1/2 digit display, 0.1pF to 20,000uF in 9 ranges, zero adjustment of +/- 20pF to compensate for parasitic capacitance in test leads, and is fully protected from a charged capacitor. Ideal for checking unmarked capacitors. Includes test leads, 9V battery, spare fuse, and manual. Net weight: 3/4 lb.
  • BrandParts Express
  • Part Number390-735
  • UPC844632013256
  • Product CategoryLC / LCR Meters
    (9 Reviews)
  • Weight1.32 lbs.
View similar products to the Digital Handheld Capacitance Meter
in the LC / LCR Meters product category.
Digital Handheld Capacitance Meter is rated 4.5556 out of 5 by 9.
Rated 5 out of 5 by from Does the JobPrompt delivery. Tested some new capacitors and old ones and it was very easy to use. The contact wires are short but otherwise it was a great buy.
Date published: 2015-03-17
Rated 5 out of 5 by from Hand Held Digital Capacitance MeterI recently purchased this item and received it quickly.It has a nice form factor and a double bailing arm to give a wide range of tilted positions. The meter has a great range of capacitanceand is accurate.I would buy again from this company.
Date published: 2015-03-11
Rated 4 out of 5 by from Very good!Easy to use, well built, accurate. I wanted one for a long time but could not affordit. Price is OK.
Date published: 2014-03-28
Rated 5 out of 5 by from To Measure is to KnowGood price. Well built and appears to have all the ranges needed. Easy to use.
Date published: 2014-01-31
Rated 5 out of 5 by from Great meter for the moneyNice meter! I did a few accuracy with capacitors of a known and calibrated value and the meter was right on the money.This type of meter is essential in building high-end audio equipment, especially in circuits such as phono RIAA equalization sections or FM tuner emphasis/demphasis circuits. When you hand match resistors (with a very accurate ohm meter) and capacitors for both channels with a meter such as this, imaging and every other sonic detail you can describe improves. The same thing goes for speaker crossovers.A must have for any tech and DIY'er! the only negative is the high shipping price.Cheers,Jim, AB0EZ
Date published: 2013-01-31
Rated 4 out of 5 by from Good cap testing valueHow do you know those replacement caps you bought for your tube amp, speaker crossovers or other project are within limits? Spending the time soldering them in neatly only to find your unit is worse with the new caps is a bummer. I have used this tester on about a dozen new caps and another dozen functioning used caps: readings were all within 10% of marked values which is closer than the + - 20% spec range of most new caps. Easy to read dial and display. Rechecking same caps after off/on of meter gives same readings. You will need an insulation tester to fully test old or new caps at rated voltage which can be had for about same cost as this tester.
Date published: 2012-02-18
  • 2016-02-06T06:27CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_390-735, PRD, sort_mostRecent
Can it measure a capacitor that is still soldered in place, or does the capacitor have to be removed from the circuit ?
Asked by: CAPOK
the capacitor would need to be removed from the circuit to measure.
Answered by: Chrisf
Date published: 2015-08-11
What is the lowest cap. value this meter will measure?
Asked by: hopeagle
0.1 pf (picofarad) Is the lowest. Just remember to "zero" the test leads and keep them as still as possible when testing for low values.
Answered by: bigrich
Date published: 2012-09-17
Will this work for inductors?
can I use this for verifying size and accuracy of inductors? and will this help me when winding my own inductors/coils for crossovers? will it verify the inductor is correct as to size given.
Asked by: Strader
No. This meter is for capacitance only. For inductance, you'd want a meter such as the one linked below (which will also measure capacitance, conveniently enough).
Answered by: RussR
Date published: 2011-12-09
  • 2016-02-06T07:32CST
  • loc_en_US, sid_390-735, PRD, sort_recentQuestionsFirst
