Desoldering Pump
Desoldering Pump
Fast action, heavy duty desoldering pump. Simply heat up solder joint and push button. Automatic nozzle cleaner. Display packaged. Standard replacement tip #370-031.
  • High Quality Aluminum Body
  • Replaceable tip
  • Fast Action Automatic Solder Sucker
  • Self Cleaning Tip
370-030
Weight: 0.16 lbs.
IN STOCK
List Price$7.99
You Save43%
$4.48
Buy 4-99 $3.94
Buy 100-up$3.25
Part # 370-030
Desoldering Pump
Fast action, heavy duty automatic desoldering pump. Simply heat up solder joint, push button and solder jumps into the tube. Reset and do it again in only seconds. This solder sucker has a built in automatic nozzle tip cleaner. Display packaged. Standard replacement tip #370-031. Length: 8".
Desoldering Pump
  • BrandParts Express
  • Part Number370-030
  • UPC844632010095
  • Product CategoryDesoldering Tools
    (24 Reviews)
  • Weight0.16 lbs.
View similar products to the Desoldering Pump
in the Desoldering Tools product category.
Desoldering Pump
Desoldering Pump is rated 4.3478 out of 5 by 23.
Rated 4 out of 5 by from Must have toolDesoldering pump works pretty good. recommend getting a spare tip. Quality is good.
Date published: 2014-01-31
Rated 5 out of 5 by from Pump it up !Great desoldering pump. Make my job much easier and very neat
Date published: 2014-01-26
Rated 5 out of 5 by from Simple, effective and compactThis desoldering pump is my second one. I wore the first one out after eight years of regular use. I like this method better than solder braid for most situations, especially the larger scale terminals frequently found in tube audio. I have used this technique on smaller pc desoldering jobs as well. It simply works well, doesn't require additional plugged-in appliances, and it's compact.
Date published: 2013-09-04
Rated 5 out of 5 by from Great desoldering tool, excellent value for money.I bought this to replace a similar desoldering tool that I had owned for about 20 years or more. The old one flew apart when I was cleaning it and "it went off".This product is an excellent replacement, in fact it seems to work better. Maybe because it has a new spring and and smaller bore nozzle than my old one, I don't know. My only concern is the tip which is all one piece molded, as opposed to my old one that was metal with a plastic insert. But this problem is easily solved by buying a spare tip when you buy it. Let's hope Parts Express carry replacement tips for a long time.
Date published: 2013-07-18
Rated 5 out of 5 by from Awesome!For quite some time I had been soldering without one of these. Now that I have it, I question how I was able to work without it! Works wonders for removing components from boards and for fixing those little mistakes ;) I especially like the self-cleaning tip.
Date published: 2013-05-13
Rated 5 out of 5 by from Solid Desoldering PumpThis desoldering pump is made of solid metal. The suction power is large. You can purchase a replacement tip for $1.95. I can see it is a very durable tool.
Date published: 2013-03-17
Desoldering Pump
Customer projects that include: Desoldering Pump
Desoldering Pump
Part # 370-030
Related Products
Customers Also Bought
6V 250mA Fuse Type Lamp
Part # 070-118
Desoldering Bulb
Part # 370-040
