300-7069_ALT_0
300-7069_ALT_1
Denovo SEOS-12 Waveguide 2/3 Bolt Gloss with 1-3/8"-18 TPI Adapter
Brand:| Model: SEOS-12
The Denovo SEOS (Super Elliptical Oblate Spheroid) waveguide emerged from a community research and design effort, to provide good horizontal high frequency coverage for consistent sound anywhere in a room.
  • Nearly linear horizontal coverage for great off-axis response
  • Reduced vertical coverage for less floor/ceiling bounce and improved imaging
  • Designed for use with compression drivers crossed over at 950 Hz or above
  • 1" throat for use with 2/3-bolt compression drivers or 1-3/8"-18 TPI compression drivers with included adapter
300-7069
Weight: 1.95 lbs.
IN STOCK
List Price$49.99
You Save31%
$34.39
Buy 4-up$32.31
Part # 300-7069
The SEOS-12™ (Super Elliptical Oblate Spheroid) waveguide, from Denovo, is the end result of a community-based research and design effort to create the optimum waveguide for home audio use. Controlled directivity is realized in the consistant sound on the horizontal plane for seamless sound throughout the room, no matter the seating location. A side benefit is reduced vertical coverage for minimized floor and ceiling bounce.
Traditional horns have a horn "sound" (also referred to as honking) and internal reflections that cancel out certain frequencies or cause distortion. Denovo's SEOS waveguide provides high dynamics and SPL without the honking and added distortion plagued by other horns. Designed to be used with 2/3-bolt 1" compression drivers, but also attaches to standard 1-3/8"-18 TPI compression drivers with the included adapter. Available in matte and gloss finish.
Specifications: • Throat diameter: 1" • Driver mounting: 2/3-bolt and 1-3/8"-18 TPI (with adapter) • Recommended minimum crossover point: 950 Hz • Overall dimensions: 13.2" W x 6.5" H x 3.5" D, Cutout: 12" W x 5" H (oval shape due to screwhole locations).
  • Mounting Type2-Bolt/3-Bolt
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandDenovo Audio Inc
  • ModelSEOS-12
  • Part Number300-7069
  • UPC848864003115
  • Product CategoryHorns & Waveguides
  • Weight1.95 lbs.
View similar products to the Denovo SEOS-12 Waveguide 2/3 Bolt Gloss with 1-3/8"-18 TPI Adapter
in the Horns & Waveguides product category.
Customer projects that include: Denovo SEOS-12 Waveguide 2/3 Bolt Gloss with 1-3/8"-18 TPI Adapter
