Denovo Audio Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for 15" Subwoofer
Brand:|Part # 300-7083
To get the most performance out of a subwoofer, you need a great cabinet. This subwoofer cabinet is precut with a common 15-3/16" resess and 13-7/8 hole.
List Price$169.99
Regular Price$125.00
You Save21%
Sale Price
$99.00
Part # 300-7083
  • 3 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio DVC385-88 15" subwoofer
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet works for any subwoofer with an overall diameter of less than 15-3/16", and a cutout requirement of less than 13-7/8". You can dial in performance from a Qtc of 0.632 with minimal fill for an f3 of 41 Hz, or add three pounds of Acousta-Stuf for a critically damped Qtc of 0.583 with an f3 of 44 Hz.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 15" DVC subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 3.0 cubic feet • External dimensions: 19.25" H x 19.25" W x 20" D • Subwoofer recess: 7/16" • Weight: 52 lbs. • Made in the U.S.A.
  • BrandDenovo Audio Inc
  • Part Number300-7083
  • UPC848791000744
  • Product CategorySubwoofer Speaker Cabinets
    (2 Reviews)
  • Weight49.05 lbs.
View similar products to the Denovo Audio Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for 15" Subwoofer
in the Subwoofer Speaker Cabinets product category.
