Denovo Audio Knock-Down MDF 1.5 cu. ft. Subwoofer Cabinet for Dayton Audio 12" Reference Series HO Subwoofer
Brand:|Part # 300-7077
Build a refined, musical subwoofer! All it takes is this 1.5 cubic foot subwoofer cabinet and the high-end Dayton Audio 12" Reference Series High Output subwoofer it was designed for. Assembles in minutes, just add wood glue.
List Price$129.99
You Save27%
$95.00
Part # 300-7077
  • 1.5 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio RSS315HO-4 12" subwoofer when used with a plate amp with bass boost
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio RSS315HO-4 12" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 12-3/8" or less, and a cutout requirement of 11-1/8" or less. For optimum performance, the cabinet is oversized to allow for the use of a plate amplifier with bass boost (such as the Dayton Audio SPA250 or Dayton Audio SPA500 plate amplifiers) to extend the frequency response while staying musical.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 12" Reference Series High Output subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and subwoofer volume): 1.25 cubic feet • External dimensions: 15.5" H x 15.5" W x 16.25" D • Subwoofer recess: 1/2" • Weight: 37 lbs. • Made in the U.S.A.
  • BrandDenovo Audio Inc
  • Part Number300-7077
  • UPC848791000683
  • Product CategorySubwoofer Speaker Cabinets
    (3 Reviews)
  • Weight32.6 lbs.
View similar products to the Denovo Audio Knock-Down MDF 1.5 cu. ft. Subwoofer Cabinet for Dayton Audio 12" Reference Series HO Subwoofer
in the Subwoofer Speaker Cabinets product category.
Denovo Audio Knock-Down MDF 1.5 cu. ft. Subwoofer Cabinet for Dayton Audio 12" Reference Series HO Subwoofer is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Solid as a Rock!With the right woofer and ports, these cabinets can really make a high end system.Thanks Parts Express!
Date published: 2015-10-02
Rated 5 out of 5 by from Works like a dreamI got one of these with my new Morel subwoofer. Just some bar clamps and some Tite Bond II and you have a strong enclosure. Because it is CNC cut, everything lines up really easy. After assembly; hit it with a sander and paint, or veneer. I highly recommend this product!
Date published: 2015-04-06
Rated 5 out of 5 by from Great subwoofer inclosureI purchased this cabinet to house a reference series 12" sub I have. I originally had a sub120 that I converted to a sealed inclosure and was using the RSS315HO in it with a Dayton SA240 amp. I decided to upgrade the amp to a SPA500 but it wouldn't fit in the sub-120 cabinet. I decided to give this cabinet a try. It went together very easy and is very solid. I used clamps to hold it together while the glue set up. I bought a ratcheting band clamp that worked great and would recommend using one during assembly. I did find out there is some required trimming of the internal bracing in order for the SPA500 plate amp to fit. Without trimming there isn't enough depth for the amp to fully seat in the cabinet. The RSS315HO is a tight fit in the cutout face. It might have been some over spray when I painted it too. I just sanded the opening and it fits very snug. I caulked all of the interior seams as well. I ended up priming the cabinet and then painting it. I installed some speaker spikes on the bottom as well. So far it sounds great in my home theater setup. Much easier then trying to build one from scratch. I might purchase a grill kit to give it more of a finished look but for now I think it's fine. Also this setup is a tank as well. The finished product weighs 65 lbs!!
Date published: 2013-11-12
  • 2016-02-06T06:36CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_300-7077, PRD, sort_mostRecent
Hi, I'm planning on using a woofer with an exact outer dimension of 12" in the Denovo 1.5 box. The Dayton 12" RSS315FH is 12.36". Is there enough stock around the router opening to accommodate a slightly smaller woofer?what is exact dimension?
Asked by: kCooke
The recess is 12-3/8" in diameter and the through-hole cutout is 11-1/8". This should accommodate most 12" woofers without a problem.
Date published: 2016-01-14
Would this box work with a Dayton Audio TIT320C-4 12" Titanic Mk III Subwoofer?  I would be using a 600 watt external amplifier.
Asked by: Prime23
Yes this will work well with that woofer, although you may need to modify the cutouts in order for it to fit properly.
Date published: 2015-08-25
I just dry fitted the cabinet together and noticed that the brace that fits in the routered slot in the back panel is going to interfere with the Bash 300 amp that I'm going to use. Am I missing something or does that brace have to be removed to work?
Asked by: lew52
You want to cut the hole for your amplifier in the back panel of the box prior to assembly to make sure it's the correct size.  I recommend first cutting an experimental hole on a piece of cardboard to make sure it's right, then transfer that cutout to the rear panel.After you cut the hole for your amp, assemble the cabinet just like you normally would.  Then cut away the portion of the horizontal brace that goes across the rear panel where your amp will be installed.  This does not weaken the enclosure because you are actually replacing the MDF wood with the thick metal frame of your amplifier.
Answered by: Erich H
Date published: 2015-08-06
Will this cabinet work with an Infinity 1260W subwoofer?
Asked by: BenBoozer
Date published: 2015-07-27
Do you have a 1.5 cabinet with a blank front?
Asked by: salami
No, we currently do not.
Answered by: MattW
Date published: 2015-04-03
I'm wondering if the cabinet could be used for a sealed guitar extension speaker. Or should it be ported? the speaker I'm using is a Celestion B12 Vintage.
Asked by: JohnHS
I suppose it could be, although this cabinet is designed to be non resonant. Usually you will want a thinner, non braced enclosure for a guitar speaker. I doubt porting will add much benefit for an application like that.
Date published: 2015-03-17
  • 2016-02-06T07:43CST
  • co_hasquestionsanswers, tq_19
  • loc_en_US, sid_300-7077, PRD, sort_recentQuestionsFirst
