Denovo Audio Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
Brand:|Part # 300-7080
Build the ultimate subwoofer using this precision CNC-machined subwoofer cabinet that is purpose built to use with Dayton Audio's 10" Ultimax subwoofer.
List Price$139.99
You Save32%
$95.00
Part # 300-7080
  • 1.25 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio Ultimax 10" subwoofer
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 10" Ultimax subwoofer, but works for any subwoofer with an overall diameter of 10-3/4" or less, and a cutout requirement of 9-9/16" or less. When used together with minimal fill, the box and subwoofer combine to create a critically damped subwoofer with a Qtc of 0.589 and an f3 of 45 Hz.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with rabbeted recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 10" Ultimax subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 1.25 cubic feet • External dimensions: 15.25" H x 15.25" W x 15.25" D • Subwoofer recess: 1/2" • Weight: 35 lbs. • Made in the U.S.A.
  • BrandDenovo Audio Inc
  • Part Number300-7080
  • UPC848791000713
  • Product CategorySubwoofer Speaker Cabinets
    (2 Reviews)
  • Weight34.9 lbs.
View similar products to the Denovo Audio Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
in the Subwoofer Speaker Cabinets product category.
