Denovo Audio Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
Brand:|Part # 300-7066
Build your own tower speaker cabinet in minutes with this CNC-cut cabinet.
List Price$79.99
You Save18%
$65.74
Buy 3+$63.33
Part # 300-7066
  • CNC-cut, acoustically inert MDF panels for precise fit and finish
  • 1.16 cu. ft. internal volume
  • Build your own tower or large format center channel speaker
  • Assembles in minutes
  • Made in the U.S.A.
CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills, perfect for DIYers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and rear panels to ensure a tight, secure fit that maximizes the gluing surface and making assembly that much easier. This tower cabinet allows you to create your very own front left or right tower speaker... or even a large format center channel speaker! Three included window braces add structural integrity while consuming as little internal volume as possible.
Additionally, users can mount side-firing a woofer (up to 8" maximum is recommended) for a modern 3-way design. The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Note: Panel dimensions and a 3D SketchUp model are included in the Manuals/Resources section. To open and use the 3D model, you need to download and install a program to unzip the file (7-Zip is free and recommended) and then download and install SketchUp to open the .skp file.
Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 1.16 cubic feet • External dimensions: 34" H x 8" W x 11" D • Internal dimensions: 32-1/2" H x 6-1/2" W x 9-1/2" D • Made in the U.S.A. • Sold individually.
  • BrandDenovo Audio Inc
  • Part Number300-7066
  • UPC844632007286
  • Product CategoryKnock-Down Flat-Pack Speaker Cabinets
    (2 Reviews)
  • Weight27.75 lbs.
Denovo Audio Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from About what I expectedI found these cabinets easy to assemble. I used the rear panel to hold the braces in place while I applied glue to the side panels. I'll finish gluing on the rear and front panels after I drill vent hole and apply my finish to the front baffle.I didn't have to use a mallet but clamps help to hold things in place while the glue sets up. I used plain yellow wood glue.
Date published: 2014-01-30
Rated 3 out of 5 by from This cabinet is ok..IF you know what you are doing,IF you get ALL corners trued..This product needs some helpful hints or instructions.
Date published: 2013-10-24
  • 2016-02-06T06:36CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-7066, PRD, sort_mostRecent
What would be the best setup to use these cabinets with two Dayton ND140'S in one box...as is sealed or ported?  Also same question but with HIVI M6N's two in each box?  Just trying to figure the best balance using HiVi RT1C-A as the high end.
Asked by: Steve007
Vented would be better for either option. The HiVi's look better in that volume with a 3" diameter, 6" long port for a tuning frequency of 44 Hz.
Date published: 2015-12-16
Hi guy's..can i make a custom 4-way speaker adding ( 1 - Dayton Silk Dome Tweet / 3 - Dayton ND140 ?
Asked by: Jt32
Date published: 2015-10-09
How wide (i.e. 1/4", 1/2", etc.) are the round-overs on the baffle? Thanks
Asked by: Inquiring
According to the drawings, these round overs are 1/8".
Date published: 2015-07-23
Hi. I just want to confirm that this product does not have any cut outs for the speakers? I have to jigsaw holes for the drivers yes?  Thanks so much
Asked by: Michael100001
That is correct, this enclosure does not have any cutouts.
Can an 8 inch woofer fit this cabinet
Asked by: Autumnboy
An 8" will be a tight fit since the baffle is 8" in diameter and has rounded edges. You could mount the drivers on the side of the cabinet and use that as the front, but one side will have rounded edges and the other wont.
Date published: 2015-05-14
Hello, are any of the panels rounded over or are they all 90 degree square corners? If any are rounded over, which ones?
Asked by: skalos
No, none of the panels are rounded.
Answered by: MattW
Date published: 2015-04-09
  • 2016-02-06T07:44CST
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_300-7066, PRD, sort_recentQuestionsFirst
