245-305_ALT_0
245-305_ALT_1
245-305_ALT_4
Deep Floor Box with 6 XLR Brass 6" x 6"
Floor boxes provide an attractive, convenient, and durable means of temporarily connecting mic, line, or speaker cables.
  • Attractive and durable way to conceal connections
  • Brass and steel construction
  • Classic brass finish
  • Connector plate is removable for easy installation
  • Ideal for theaters, schools, and houses of worship
245-305
Weight: 5.9201 lbs.
IN STOCK
List Price$110.99
You Save19%
$88.94
Buy 4-up$77.22
Part # 245-305
Floor boxes provide an attractive, convenient, and durable means of temporarily connecting mic, line, or speaker cables. Although built to withstand the wear and abuse of floor mounting, they may also be wall mounted whenever that application requires a sleek, stealthy appearance. The beveled faceplates are cast in solid brass, and the other metal parts and fittings are painted or plated, which ensures long-term protection against occasional exposure to moderate moisture. The Floor Box includes six female XLR and two female 1/4" connectors loaded in a deep-well housing that permits the lid to be closed when in use. The boxes are intelligently designed and carefully constructed to provide years of exceptional service, and will accept standard knockout cable fittings.
Features: • floor box mounting space requirements: 5.25" square x 5.25" deep • Faceplate dimensions: 5.75" square • Faceplate finish: Natural brass • Connectors: 6 x XLR female, and 2 x 1/4" TRS female • Top plate screws are spaced at 3-3/" • Removable mounting plate measures 4" x 4.5" • 1" diameter knock-outs.
  • BrandParts Express
  • Part Number245-305
  • UPC844632009150
  • Product CategoryFloor / Stage Boxes
    (10 Reviews)
  • Weight5.9201 lbs.
View similar products to the Deep Floor Box with 6 XLR Brass 6" x 6"
in the Floor / Stage Boxes product category.
Deep Floor Box with 6 XLR Brass 6" x 6" is rated 3.4 out of 5 by 10.
Rated 3 out of 5 by from Good overall, but you get what you pay for.First of the all price is great, try buying anything similar for less than 2x what you'll pay for this. Having said that, there are some things Dayton Audio could improve on. First, drop the stupid rubber feet as plugs, it just makes it look like they didn't care to try. I get that there would be clearance issues with non-flush fitting plugs, so why not make them true knockouts like every other electrical box in the world has? Tap the threads of the adjusters all the way so the top plate screws can go in without stripping out the heads of the screws. Third, there needs to be more room under the jack plate for the wiring, It's tight in there, just take the stupid plugs out and look how close the wiring is to the floor of the box. Now for the other comments about not having connections pre-soldered and a pigtail hanging out? I'd suggest others ignore those comments, the less connections the better. This isn't a temporarily connection, it's permanent so why not solder it together and make it permanent?
Date published: 2013-10-28
Rated 4 out of 5 by from Great Value and looks and works goodThe Brass OR the Black pockets look and work good, and are far less expensive (1/4th the cost) than othe stage pockets. Be careful to use the jig provided for the hole size that you cut into the stage, for there is little room for error on that. (There is not much of a flange area for the box to sit on. Otherwise this box is a snap to use.
Date published: 2013-09-23
Rated 4 out of 5 by from coolrealy helps the stage look better
Date published: 2009-12-13
Rated 4 out of 5 by from Very goodWe have to enlarge the knock-out from 1/2" to 3/4". This is no problem.
Date published: 2009-08-10
Rated 4 out of 5 by from Great floor box for the price!!This floor box has a super high luster finish and looks like something that would cost 3 or 4 times as much. It is nice and compact with plenty of room for your connections. The XLR plate comes out through the top of the cover. There are a couple of drawbacks. The first drawback is that there are no mounting instructions. I suppose if you drop it in and are not worried about sercueing it, then you'll be fine. The second drawback is that the cover overhang is only about 3/8 of an inch; not much room to make a mistake on cutting the floor! I do a lot of church sound installations and this box is well worth the money(and by the way it looks really great)!
Date published: 2008-09-16
Rated 2 out of 5 by from Poor design - time consuming installCover looks great but the cableflaps wil not hold more than 2 wires each with out the lid popping up. The install is slow because there is only a box and cover with no way to conect the thing to the floor. It takes some drilling and screws to make it work.The worst feature is the shallow space under the connector plate. there is no room to put your wire leads after you solder. And don't even try to use this with conduit...you can't put the plate in the box becuse there is so little room underneath. After 20 plus years of installs, this has to be the worst designed box i have used!!! Never again.
Date published: 2008-04-29
Customer projects that include: Deep Floor Box with 6 XLR Brass 6" x 6"
Related Products
Customers Also Bought
