246-107_ALT_0
246-107_ALT_1
dbx 234xs Stereo 2/3-Way / Mono 4-Way Crossover (XLR only)
Brand:| Model: 234XS
The secret to making speakers sound great lies with the crossover you use. With the dbx® 234xs Crossover you'll get great performance, ultra low-noise, rugged reliability and four decades of dbx knowledge and expertise in building the world's finest processors.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
  • XLR balanced ins and outs
  • Mode switches for mono 4-way or stereo 2-way/3-way operation
  • Low frequency summed (subwoofer) output
  • Phase reverse switch on all outputs
  • CSA NRTL/C approved
  • CE compliant
  • 2 year manufacturer's warranty
246-107
Weight: 6.95 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$339.95
You Save29%
$239.95
Part # 246-107
The secret to making speakers sound great lies with the crossover you use. With the dbx® 234xs Crossover you'll get great performance, ultra low-noise, rugged reliability and four decades of dbx knowledge and expertise in building the world's finest processors. The 234xs uses precision filters to separate the audio signal and direct the correct frequencies to your loudspeaker drivers. By directing only the specific frequency bands to each speaker driver the 234xs leaves your amplifiers free to use their full power on the usable signal eliminating distortion and giving your PA system a cleaner and better sound.
The dbx 234xs is a dual channel crossover with all the features you would expect from a professional product. It features Linkwitz-Riley 24 dB per octave filters, independent output gain controls for level matching, output phase inversion, 40 Hz low cut filter, and optional mono summing of the low frequency (subwoofer) output. Everything in the design exudes great precision from the solid "click" controls to the high quality XLR inputs and outputs.
Inputs: • Connectors: XLR • Type: Electronically balanced/unbalanced, RF filtered • Impedance: Balanced >50k ohm, unbalanced >25k ohm • Max Input Level: >+21 dBu balanced or unbalanced
Outputs: • Connectors: XLR • Type: Electronically-balanaced/unbalanced, RF filtered • Impedance: Balanced 60 ohm, unbalanced 300 ohm • Max output level: >+20dBu balanced/unbalanced into 600 ohms or greater
Crossover Frequencies: • Stereo mode: Low/High 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting), Low/Mid 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting), Mid/High: 450 Hz to 9.6 kHz (x10 setting) • Mono mode: Low/Low-Mid 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting), Low-Mid/High-Mid 450 Hz to 9.6 kHz, High-Mid/High 450 Hz to 9.6 kHz • Filter type: Linkwitz-Riley, 24 dB/octave, state-variable
Function Switches: • Front panel (Low Cut): Activates 40Hz Butterworth, 12 dB/octave high-pass filter, one switch per channel • Phase invert: Inverts the phase at the output, one switch per output • Rear panel: x10: Multiplies crossover frequency range by 10, one switch per channel • Mode: Selects stereo/mono and 2/3/4-way operation   • LF sum: Selects normal (stereo) or mono-summed low frequency operation
Overall System Specifications: • Bandwidth: 20 Hz to 20 kHz, +0/-0.5 dB • Frequency response: <3 Hz to >90 kHz, +0/-3 dB • Dynamic range: >106 dB, unweighted, any output • Signal-to-Noise (Ref: +4 dBu, 22 kHz measurement bandwidth): Stereo mode >94 dB (Low Output), >93 dB (Mid Output), >90 dB (High Output); Mono mode >94 dB (Low Output), >94 dB (Low/Mid Output), >92 dB (High/Mid Output), >88 dB (High Output) • THD + Noise: <0.004% at +4 dBu, 1 kHz; < 0.04% at +20 dBu, 1 kHz • Interchannel Crosstalk: < -80 dB, 20 Hz to 20 kHz • Common mode rejection: >40 dB, typically >55 dB @ 1 kHz • Operating voltage: 100-120 VAC 50/60 Hz; 120 VAC 60 Hz • Power requirements: 15 watts • Operating temperature: 32°F to 113°F (0°C to 45°C) • Dimensions: 1.75" H x 6.9" D x 19" W (4.5 x 17.5 x 48.26 cm) • Weight: 4.0 lbs. (1.8 kg).
  • Branddbx
  • Model234XS
  • Part Number246-107
  • UPC691991401299
  • Product CategoryActive Crossovers
    (1 Reviews)
  • Weight6.95 lbs.
View similar products to the dbx 234xs Stereo 2/3-Way / Mono 4-Way Crossover (XLR only)
in the Active Crossovers product category.
dbx 234xs Stereo 2/3-Way / Mono 4-Way Crossover (XLR only) is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Bang for the buckThis unit is worth every penny paid for it! I have known about dbx products for a long time and finally purchased this one out of need. Craftmanship and quality are both in this unit and is less expensive than other makes with the same specs. Great value and product.
Date published: 2013-05-25
How to run crossover two way
Asked by: sitar0334
Please consult the manual below for operating and hookup instructions. If you need further help you can contact dbx or our tech support via email or phone.www.parts-express.com/pedocs/manuals/246-107-dbx-234xs-manual-44052.pdf
Date published: 2014-10-14
Customer projects that include: dbx 234xs Stereo 2/3-Way / Mono 4-Way Crossover (XLR only)
