dbx 234s Stereo 2/3-Way / Mono 4-Way Crossover
Brand:|Model: 234S|Part # 246-103
If you want great performance, ultra low-noise, rugged reliability and four decades of dbx knowledge and expertise in building the world's finest processors then the 234s crossover is for you.
List Price$249.00
You Save20%
$199.95
Part # 246-103
  • Mode switches for mono 4-way or stereo 2-way/3-way operation
  • Low frequency summed (subwoofer) output
  • Phase reverse switch on all outputs
  • Stereo/Mono status LEDs indicate the selected mode
  • CSA NRTL/C approved
  • CE compliant
  • 2 year manufacturer's warranty
If you want great performance, ultra low-noise, rugged reliability and four decades of dbx knowledge and expertise in building the world's finest processors then the 234s crossover is for you. The 234s uses precision filters to separate the audio signal and direct the correct frequencies to your loudspeaker drivers. By directing only the specific frequency bands to each speaker driver the 234s leaves your amplifiers free to use their full power on the usable signal eliminating distortion and giving your PA system a cleaner and better sound. dbx's 234s dual channel crossover has everything you would expect from a professional product. It features independent output gain controls for level matching, Linkwitz-Riley 24 dB per octave filters, output phase inversion, 40 Hz low cut filter, and optional mono summing of the low frequency (subwoofer) output. Everything in the design exudes great precision from the high quality 1/4" TRS inputs and outputs to the solid "click" controls.
Inputs: • Connectors: 1/4" TRS • Type: Electronically balanced/unbalanced, RF filtered • Impedance: Balanced >50k ohm, unbalanced >25k ohm • Max input level: >+22 dBu balanced or unbalanced • CMRR: >40 dB, typically >50 dB at 1 kHz
Outputs: • Connectors: 1/4" TRS • Type: Impedance-balanaced/unbalanced, RF filtered • Impedance: Balanced 200 ohm, unbalanced 100 ohm • Max output level: >+21 dBu balanced/unbalanced into 2k or greater
Crossover Frequencies: • Stereo mode: Low/High 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting); Low/Mid 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting); Mid/High: 450 Hz to 9.6 kHz (x10 setting) • Mono mode: Low/Low-Mid 45 to 960 Hz or 450 Hz to 9.6 kHz (x10 setting); Low-Mid/High-Mid 450 Hz to 9.6 kHz; High-Mid/High 450 Hz to 9.6 kHz • Filter type: Linkwitz-Riley, 24 dB/octave, state-variable
Function Switches: • Front panel (Low Cut): Activates 40 Hz Butterworth, 12 dB/octave high-pass filter, one switch per channel • Phase invert: Inverts the phase at the output, one switch per output • Rear panel: x10: Multiplies crossover frequency range by 10, one switch per channel • Mode: Selects stereo/mono and 2/3/4-way operation
• LF sum: Selects normal (stereo) or mono-summed low frequency operation
Overall System Specifications: • Bandwidth: 20 Hz to 20 kHz, +0/-0.5 dB • Frequency response: <3 Hz to >90 kHz, +0/-3 dB • Dynamic range: >106 dB, unweighted, any output • Signal-to-Noise: Ref: +4 dBu, 22 kHz measurement bandwidth • THD + Noise: <0.004% at +4 dBu, 1 kHz; <0.04% at +20 dBu, 1 kHz • Interchannel crosstalk: < -80 dB, 20 Hz to 20 kHz • Common mode rejection (Ref: +4 dBu, 22 kHz measurement bandwidth): Stereo mode >94 dB (Low Output), >93 dB (Mid Output), >90 dB (High Output); Mono mode >94 dB (Low Output), >94 dB (Low/Mid Output), >92 dB (High/Mid Output), >88 db (High Output) • Operating voltage: 100-120 VAC 50/60 Hz; 120 VAC 60 Hz • Power requirements: 15 watts • Operating temperature: 32°F to 113°F (0°C to 45°C) • Dimensions: 1.75" H x 6.9" D x 19" W (4.5 x 17.5 x 48.26 cm) • Weight: 4.0 lbs. (1.8 kg).
  • Branddbx
  • Model234S
  • Part Number246-103
  • UPC691991401282
  • Product CategoryActive Crossovers
    (1 Reviews)
  • Weight6.9 lbs.
View similar products to the dbx 234s Stereo 2/3-Way / Mono 4-Way Crossover
in the Active Crossovers product category.
