dbx 215s Dual 15-Band Graphic Equalizer
Brand:|Model: 215S|Part # 246-143
The dbx 215s offers exceptional sound and rugged reliability that guarantees you will always sound your best.
List Price$199.00
You Save20%
$159.95
Part # 246-143
  • Dual 15-band, 1/3-octave Constant Q frequency bands
  • Switchable boost/cut ranges of ±6 or ±12 dB
  • Front panel bypass switch
  • ±12 dB input gain range
  • 4-segment LED ladders for monitoring output levels
  • XLR and TRS inpts and outputs
  • Dynamic range of greater than 108 dB
With over four decades in the business, dbx sets the standards for touring, studios, and audio installations. When it comes to EQs, dbx is who the pros turn to. With the dbx heritage of revered pro EQs, the 215s meets the needs of the most demanding sound reinforcement environments, while offering the simplicity of straightforward controls. The dbx 215s offers exceptional sound and rugged reliability that guarantees you will always sound your best.
The dbx 215s features • two 15-band channels of 2/3-octave equalization • ±12 dB input gain • switchable ±6 dB or ±12 dB boost/cut range • 20 mm nonconductive sliders • an intuitive user interface • output level metering. From its extended 10 Hz to 50 kHz frequency response and 112 dB dynamic range to the quality and meticulous attention to detail this EQ is second to none! Sure to find a home in the studio, on tour and with installed sound venues, the dbx 215s is destined to take its rightful place in the lineage of great dbx signal processors that are the professional's choice in signal processing. With such affordable quality, there's no longer any excuse for compromising your sound.
Inputs: • Connectors: 1/4" TRS, female XLR (pin 2 hot) • Type: Electronically balanced/unbalanced, RF filtered • Impedance: Balanced 40k ohm, unbalanced 20k ohm • Max input level: >+21 dBu balanced or unbalanced • CMRR: >40 dB, typically >55 dB at 1 kHz
Outputs: • Connectors: 1/4" TRS, male XLR (pin 2 hot) • Type: Impedance-balanaced/unbalanced, RF filtered • Impedance: Balanced 100 ohm, unbalanced 50 ohm • Max output level: >+21 dBu balanced/unbalanced into 2k ohm or greater • >+18 dBm balanced/unbalanced (into 600 ohms)
Function Switches: • EQ bypass: Bypasses the graphic equalizer section in the signal path • Low cut: Activates the 50 Hz 12 dB/octave high-pass filter • Range: Selects either ±6 dB or ±12 dB slider boost/cut range
Overall System Specifications: • Bandwidth: 20 Hz to 20 kHz, +0.5/-1 dB • Frequency response: <10 Hz to >50k Hz, +0.5/-3 dB • Dynamic range: Typically >112 dB • Signal-to-Noise: Typically >95 dB • THD+Noise: <0.003% • Interchannel crosstalk: <-90 dB, 20 Hz to 20 kHz • Operating voltage: 100 VAC-240 VAC 50/60 Hz • Power consumption: 15 watts • Mains connection: IEC receptacle • Dimensions: 1.75" H x 6" D x 19" W (4.4 x 15.24 x 48.26 cm)  • Weight: 4.8 lbs. (2.2 kg).
  • Branddbx
  • Model215S
  • Part Number246-143
  • UPC691991401220
  • Product CategoryEqualizers
    (2 Reviews)
  • Weight5.7 lbs.
View similar products to the dbx 215s Dual 15-Band Graphic Equalizer
in the Equalizers product category.
