246-146_ALT_0
246-146_ALT_4
dbx 1215 Dual 15-Band Graphic Equalizer
Brand:|Model: 1215|Part # 246-146
The dbx®12 Series graphic equalizers were designed to meet the needs of the most demanding sound reinforcement environments, while offering the simplicity of straightforward controls.
Part # 246-146
  • Switchable boost/cut ranges of ±6 or ±15 dB
  • Electronically balanced/unbalanced inputs
  • Servo balanced/unbalanced outputs
  • RF filtered inputs and outputs
  • XLR, barrier strip, and 1/4" TRS connectors
  • -12 dB/+12 dB input gain range
  • 18 dB/octave 40 Hz Bessel low-cut filter
Frequently Bought Together
The dbx®12 Series graphic equalizers were designed to meet the needs of the most demanding sound reinforcement environments, while offering the simplicity of straightforward controls. The 1215 provides standard features like dual channels, fifteen 2/3 octave bands, ISO frequency centers, +/-12 dB input gain range, and switchable 40Hz/18 dB per octave low-cut filters, but also includes other thoughtful features. These include 45 mm faders; selectable +/-6dB or +/-15dB boost/cut range for precise gain adjustments; XLR, barrier strip, and 1/4'' TRS connectors for installation ease; balanced inputs and outputs for quiet operation; and chassis/signal ground lift capabilities for quick hum isolation. The visionary design of the dbx 12 Series makes your job easier.
The dbx 12 Series Equalizers were precision engineered to provide years of maintenance-free operation in any application. The magnetically isolated transformer, electronically balanced/unbalanced inputs and servo balanced/unbalanced outputs, RF-filtered inputs and outputs, and power-off hard-wire relay bypass with 2-second power up delay were steps dbx's engineers took to ensure compatibility for all installations.
Only the best components were used, yielding a 10 Hz to 50 kHz frequency response, greater than 90 dB SNR (ref +4dBu), less than 0.005% THD +Noise (1 kHz at +4dBu), and inter-channel crosstalk of less than -80 dB from 20 Hz to 20 kHz. All this attention to detail is contained in a 2U steel/aluminum chassis.
  • Branddbx
  • Model1215
  • Part Number246-146
  • UPC691991400032
  • Product CategoryEqualizers
  • Weight9.5 lbs.
View similar products to the dbx 1215 Dual 15-Band Graphic Equalizer
in the Equalizers product category.
