dbx 1066 Dual Compressor / Limiter / Gate
Brand:|Model: 1066|Part # 246-118
Want to instantly add that classic dbx® response to your mix? It's there at the touch of the "Auto" button—or use the independent Attack and Release controls to tailor the 1066 to your specific needs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$537.00
You Save20%
$429.95
Part # 246-118
  • Selectable auto (classic dbx®) or manual (variable attack and release) compression
  • Contour switch removes unwanted low frequency information from detector circuit
  • Selectable Overeasy® or Hard Knee compression modes
  • PeakStopPlus™ limiting for setting maximum allowable level with minimal distortion
  • SC Ext and SC Mon for setting up and monitoring external devices for gating function
  • Differentially balanced gold-plated XLR and 1/4" TRS inputs and outputs
  • True RMS level detection
Frequently Bought Together
Want to instantly add that classic dbx® response to your mix? It's there at the touch of the "Auto" button—or use the independent Attack and Release controls to tailor the 1066 to your specific needs. Unwanted frequencies or mic bleed in the signal path? Frequency dependent gain control is a snap to set up and execute with the Side Chain External button (SC Ext). Use the Side Chain Monitor button (SC Mon) and your favorite EQ to dial in the specific frequencies you want to trigger the device. As has become dbx's standard, the contour switch allows entire mixes to be easily smoothed with soft compression while keeping low frequencies from punching holes in the overall mix. Selectable input and output metering allow you to make sure that everything is matched up level-wise, maximizing your signal-to-noise ratio.
For overall speaker protection, dbx's new PeakStopPlus® does all previous circuits one better. With a new design, the PeakStopPlus represses those unwanted transients from blowing your drivers while minimizing the distortion common to many other "hard" limiters. Selectable Hard-Knee or OverEasy® characteristics make the 1066 ideal for your gain control needs, whether you're looking for "heavy" almost-special-effects compression or soft, smooth gain leveling. New lightpipe technology replaces standard LED's found on most other units, making the 1066 both very easy to read and much easier to operate.
In the studio, broadcast facility or on the road with a P.A. system, the 1066 is designed for perfectly simple operation. The 1066 allows you to eliminate unwanted signals, flexibly control overall signal gain and guard your overall mix in dual mono or stereo operation.
At the heart of the 1066 is the new dbx V2 VCA. Developed especially for the 1066, 1046, and other
  • Branddbx
  • Model1066
  • Part Number246-118
  • UPC691991400018
  • Product CategoryCompressor, Expander, Limiter, Gate
  • Weight7.5 lbs.
View similar products to the dbx 1066 Dual Compressor / Limiter / Gate
in the Compressor, Expander, Limiter, Gate product category.
