Dayton Audio WT3P WT3 Bundled with Precision Scale
Brand:|Model: WT3P|Part # 390-803
Don't wait! For a limited time we've bundled the popular Dayton Audio WT3 driver testing system with a digital precision scale that complements the WT3 when calculating Vas using the Delta Mass method! This precision digital scale is a $30 retail value and accurate to 0.005 of a troy ounce!
  • For a limited time, bundled with a FREE scale! A $30 value!
  • Measure speaker parameters of any driver, large or small
  • Compact USB interface with molded test leads
  • Data can be printed or saved to create a driver parameter library
  • Parameters can be exported to WinSpeakerz and other popular box design programs
  • Measures VAS using added mass, test box, or SPL method
  • Straightforward, easy-to-use measurement software
Order a Dayton Audio WT3 Woofer Tester today and start testing your drivers using the most affordable speaker analysis test device available, and get a FREE precision scale! Dayton Audio's WT3 makes measuring loudspeaker parameters faster and more accurate than ever before. Previous generation woofer testers took around 6 minutes to measure 30 impedance points, while the new WT3 measures over 30,000 data points in a few seconds using an exclusive swept sine technique. The result is a high-resolution impedance measurement that allows for the extraction of extremely accurate driver parameters giving you the accurate measurements you need in a fraction of the time. Free air resonance may be measured in a few seconds. VAS can be measured by traditional test box, added mass or by specifying the 1W/1m SPL of the driver. No other loudspeaker impedance tester is as fast or as easy to use! WT3 hardware consists of a tiny USB interface device with cable and alligator leads. Windows-based software provides an easy-to-use interface that allows you to be testing very quickly. You can save as many as 20 impedance measurements per project and then overlay and compare measurements to create a custom report. Ideal for speaker QC.
  • BrandDayton Audio
  • ModelWT3P
  • Part Number390-803
  • UPC844632070723
  • Product CategorySPL Meters / Audio Analyzers
    (34 Reviews)
  • Weight0.65 lbs.
View similar products to the Dayton Audio WT3P WT3 Bundled with Precision Scale
in the SPL Meters / Audio Analyzers product category.
