Dayton Audio VS8 8" Universal Low-Profile Subwoofer
Brand:|Model: VS8|Part # 300-490
Ditch your "cube" – the versatile Dayton Audio VS8 low-profile subwoofer fits almost anywhere!
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$199.99
Regular Price$129.88
You Save24%
Sale Price
$99.00
Part # 300-490
  • Low-profile enclosure features less than 3" total depth
  • Powerful 8" long-excursion woofer digs deep
  • Bass reflex design produces plenty of clean, solid low frequency output
  • Multiple wiring options for maximum system flexibility
  • Clean, modern styling disappears into surroundings
  • Great performance when installed in home stereo, home theater, or car audio systems
  • Partner with a Dayton Audio SA230 amplifier for a perfectly matched subwoofer combo
The Dayton Audio VS8 subwoofer was engineered to accommodate the challenging space requirements of modern home audio installations. Despite its emphasis on compact size and flexible connectivity, the VS8's designers maintained Dayton Audio's typical commitment to faithful audio reproduction. A VS8 can be installed permanently in walls, floors, or ceilings, but is attractive enough to deploy in "opportunistic" locations like behind a sofa, beneath a table, or tucked into a corner.
Performance-wise, an 8" long-throw dual voice coil driver and complex bass reflex design that utilizes a flared port produce much more bass than is expected typically from such a small loudspeaker enclosure. The Dayton Audio VS8 low-profile subwoofer is finished in a dark brushed aluminum-look vinyl wrap that complements any décor.
The omni-directional dispersion characteristics and shallow enclosure of this subwoofer facilitate limitless placement options. The VS8 fits between wall studs, and is easy to install (requires a Dayton Audio VS8IG in-wall mounting kit, coming soon!). This subwoofer can also be mounted on the wall externally or placed behind furniture.
Down-firing use beneath furniture is aided by the VS8's included rubber feet, which elevate the subwoofer and protect surfaces. Coupling to the floor via spikes is also possible, and Dayton Audio speaker spikes (sold separately) may be installed as an alternative to the rubber feet. Or, lay the VS8 on its back and use it in an up-firing configuration.
Specifications: • 8" long-throw DVC subwoofer • Power handling: 120 watts RMS (60 watts RMS per coil) Impedance: 8 ohm single channel, 2 ohm single channel, 4 ohm dual channel • Frequency response: 35 – 200 Hz • Dimensions: 18-7/8" H x 14" W x 2-3/4" D.
  • ConfigurationSubwoofer
  • Woofer Diameter8"
  • BrandDayton Audio
  • ModelVS8
  • Part Number300-490
  • UPC844632089589
  • Product CategoryPassive Subwoofers
    (5 Reviews)
  • Weight14.7500 lbs.
View similar products to the Dayton Audio VS8 8" Universal Low-Profile Subwoofer
in the Passive Subwoofers product category.
Dayton Audio VS8 8" Universal Low-Profile Subwoofer is rated 4.0 out of 5 by 5.
Rated 5 out of 5 by from Great features!!This dual voice coil, non-powered subwoofer is most useful with the recent roll-out of Dolby Atmos. Multiple subwoofers together with corresponding three or two way bookshelf speakers allow full range speakers to be deployed at both the 'listener level' as well as the 'height level' speaker positions thus augmenting or otherwise eliminating the need for the LFE speaker(s) in a surround sound home theater system. Parts Express should strongly urge Dayton Audio to continue the production run of this speaker unit.
Date published: 2014-11-26
Rated 1 out of 5 by from Underwhelming, even considering the constraints.I have worked with speaker enclosure design software and have successfully built many speakers before. I bought this with a blind "trust" that due diligence was done in the design; however, I should have relied on my experience in that an 8" driver can not be adequately designed into an enclosure of these dimensions.One would be much better off attempting this size sub using a 6" long throw subwoofer with a passive radiator. The sensitivity was extremely low and even a 150w plate amp driving this sub did not provide enough bass to notice it was there. (I was adding this to a 6.5" MTM speaker pair.)Not worth it. Not with 2 of them, not with any number of them combined. I remember a "scary bass" project at parts express years ago... I'll likely be looking that one up and constructing it for my needs.
Date published: 2014-05-31
Rated 5 out of 5 by from Great for use in an RVWorks great with a car stereo amplifier for use in a motorhome. (Placed under jackknife sofa).
Date published: 2014-04-15
Rated 4 out of 5 by from Try it ,you'll like it.I cant say how happy I am that I came across this sub-wooferat the 2013 Midwest event, so happy in fact I bought 2.I will admit, I was skeptical at first, but do not regret mydecision. I am using these as stands/ sub-woofers for myMagnepan MMG speakers. I have the SV8 in the downwardfiring position over carpet. The SV8 is exactly the same widthas the MMG's so it is a perfect match visually. Acoustically, thematch up works perfectly for me,as the speed of the smaller 8"woofer does an outstanding job in keeping up with the MMG.The versatility of this unit is another issue all together,making this an even better deal than it already is. I willbe getting 2 more to use in another system as sub / ampstands.
Date published: 2013-08-08
Rated 5 out of 5 by from the swiss army knife of low profile subwoofer cabinetsIf you don't have the room for a traditional sub cabinet for whatever reason this is the cure and can be used in a multitude of ways . Pretty innovative design.It is meant to be matched with the SA230 sub amp with it's built in 9 db boost at 40Hz.How does it sound ?At the moment I'm using it in my exercise area to reinforce the MTM's I built in 1.0 cu. ft. cabinets with the Klipsch 6.5 buyouts ( 299-101 ) and a Vifa dome tweeter . The MTM's have excellent sound but fizzle out around 80 Hz . Now I can hear a Fender Bass , Hammond Organ or drum sound the way it needs to be . Nice round low end and gets loud enough for the area I'm using it in .Can be used up or down firing , vertically, in wall joists , on wall , in wall or under chair . behind couch . You get the idea .I don't have a sub amp.... yet. But am using the Audio Source Amp 100 bridged with an ART 31 band EQ so I can boost 40 Hz and cut off 18 db's from 100 Hz on up
Date published: 2013-07-24
  • 2016-04-30T06:10CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_300-490, PRD, sort_mostRecent
What driver is used in this speaker? I'd like to buy one for a speaker project I'm working on. Thanks.
Asked by: BWillard
Unfortunately these woofers are not available separately.
Date published: 2016-03-31
What is this subwoofer enclosure tuned to?
Asked by: Pain for Fun
This is tuned to roughly 30 Hz.
Date published: 2016-03-03
can 2 of these be wired into a 2 ohm final load?
Asked by: Cruxie
No, a pair of these could only be wired to a 4 or 1 ohm overall load.
Date published: 2015-09-19
I got 2 of these subs but one of them often rattles and/or has hums during movie playback. Would it be the problem of the sub or with the amp? I output the sub signal through my Yamaha receivers, 2 sub outs to a stereo amp and then to the subs. Thanks.
Asked by: yklivan
This will require a bit of troubleshooting. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-01-09
If I put this behind the couch, will that significantly reduce the sound quality of the bass coming out of it?
Asked by: TLudlam
The quality of the sound should not differ as long as you leave an appropriate amount of room in front of the woofer and port.
Date published: 2014-04-14
How would I wire this with Dayton MA1240A?
Asked by: E38Guy
This depends on how you intend to use the two together. I would recommend emailing or calling our tech department for a bit more info regarding this type of connection.
Date published: 2014-03-03
  • 2016-04-30T06:43CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_300-490, PRD, sort_recentQuestionsFirst
