Dayton Audio UMM-6 USB Measurement Microphone
Brand:|Model: UMM-6|Part # 390-808
Dayton Audio's UMM-6 USB measurement microphone matches the level of precision previously offered only by expensive measurement equipment.
List Price$119.95
You Save25%
Buy 4+$79.99
Part # 390-808
  • Precision condenser microphone for critical measurement and recording applications
  • Connects to your PC or Mac via USB port
  • True omnidirectional pattern and calibrated flat frequency response
  • Rugged construction with high-quality components
  • Compact design; includes sturdy carrying case with foam insert
  • Compatible with most industry-standard measurement software
The Dayton Audio UMM-6 professional-quality USB measurement and recording microphone is designed to work with industry-standard third party recording and measurement software. The rugged construction and compact size make it the perfect companion for audio professionals who must work on-location performing acoustic analysis, monitoring audio levels, or recording. Each UMM-6 is calibrated individually using a laboratory-standard reference microphone, for consistent, repeatable PC measurements that match the level of precision offered previously only by expensive stand-alone microphones and measurement equipment. Works great with the Room EQ Wizard software.
A carrying case with foam insert, 10 ft. USB connection cable, and a mini tripod mic stand are included with the UMM-6.
Calibration Note: A unique serialized calibration file is available for the UMM-6. This calibration file can be used by most audio-analysis software. To obtain your individual calibration file, visit Dayton Audio's website where you will be prompted to enter the serial number from the body of your UMM-6. After entering the serial number, your download will start.
Specifications: • Capsule type: Precision 6 mm electret condenser • Polar Response: True omnidirectional • Frequency response: 18-20,000 Hz (Calibrated) • Sensitivity at 1 kHz into 1K ohm: 10 mV/Pa (-40dBV, re. 0dB = 1V/Pa) • Maximum SPL for 1% THD @ 1000 Hz: 127 dB • S/N ratio: 70 dB (A-weighted) • Connector: USB B female • Weight: 148 grams.
  • BrandDayton Audio
  • ModelUMM-6
  • Part Number390-808
  • UPC848791000119
  • Product CategoryMeasurement Microphones
    (14 Reviews)
  • Weight2 lbs.
View similar products to the Dayton Audio UMM-6 USB Measurement Microphone
in the Measurement Microphones product category.
