Dayton Audio UA711CCK Speaker Kit Curved Cherry
Brand:|Model: UA711CCK|Part # 302-773
The diminutive UA711 excels as surrounds or the main L/R speakers in moderately sized rooms.
Part # 302-773
  • Designed to offer truly high-end sound quality and aesthetic appeal
  • Choice of three beautiful exterior surfaces (cherry, maple, and gloss black)
  • Choice of two cabinet styles (straight- or curved-sided)
  • Enjoy substantial savings compared to finished systems
  • No expensive tools, measurement equipment, or soldering required
  • One-hour construction time
Dayton Audio's Dr. Joseph D'Appolito-designed UA711 speaker exhibits well-behaved and consistent coverage both horizontally and vertically. A 2 kHz crossover point contributes to the excellent transition between the Usher tweeter and Usher woofer. The diminutive UA711 excels as surrounds or the main L/R speakers in moderately sized rooms. The Usher woofer's response can reach down to around 50 – 60 Hz, which is appropriate for many listening situations. For realistic home theater use, or as part of a music playback setup, the UA711 can also be used with a subwoofer to create a bigger "full range" sound. Thanks to the smooth, gentle sealed-box roll off, a THX-recommended low-frequency crossover of 80 Hz is easy to implement if required.
Specifications: • Impedance: 8 ohms • Frequency response: 54-20,000 Hz • SPL: 87 dB 2.83V/1m • Power handling: 70 watts RMS • Cabinet dimensions: 14" H x (8.5" Front, 4.5" Back) W x 13" D • Sold individually.
Dayton Audio designed its loudspeaker kits to offer the speaker-building hobbyist truly high-end sound quality and aesthetic appeal. They are available in a choice of three beautiful exterior surfaces (cherry, maple, and gloss black) and two styles (straight- or arc-sided), and are sure to blend with any decor. You will realize substantial savings by assembling them yourself.
The process requires a beginning knowledge of electronics, but does not require expensive tools or measurement equipment. No soldering required! The woodworking has been done; all that remains is to secure the drivers and ports, attach damping materials, and connect the pre-assembled crossovers to the drivers. This can usually be accomplished with a screwdriver, some sealant, and an hour of construction time.
  • Cabinet OptionsFinished
  • BrandDayton Audio
  • ModelUA711CCK
  • Part Number302-773
  • UPC844632073649
  • Product CategorySpeaker Kits
  • Weight28.8 lbs.
View similar products to the Dayton Audio UA711CCK Speaker Kit Curved Cherry
in the Speaker Kits product category.
Videos
