Dayton Audio TWC-0.50CH 0.50 cu. ft. 2-Way Curved Speaker Cabinet Cherry
Brand:|Model: TWC-0.50CH|Part # 302-723
Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing.
Part # 302-723
  • Attractive curved-sided design is extremely rigid and reduces diffraction
  • Very rich, real wood cherry veneer
  • .477 ft³ net internal volume
  • Exclusive baffle replacement system
  • Magnetic grill fasteners
If you want to create a loudspeaker without investing the time and money building one from scratch, these cabinets are the answer. Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing. Using Dayton Audio speaker cabinets will guarantee superior results every time. 3/4" MDF side and back panel construction is reinforced by a 3/4" MDF "shelf" brace running vertically up the sides and across the top and bottom. The entire cabinet, including the rear, is covered with a very rich, genuine cherry wood veneer with a semi-gloss finish. The baffle is 1" MDF with a black satin finish and rabbeted construction. It offers the flexibility of the B-REX replacement system and comes pre-finished without any driver cutouts. The grill is secured to the baffle by neo magnets in line with the machine screws that fasten the baffle to the enclosure. Two 1/4" holes on the back simplify installation of Dayton Audio knock-in binding posts. Attractive curved-sided design is extremely rigid and solid, with minimized panel resonance. Complete with baffles, hardware, and grills. Add crossover parts, port tubes, damping materials, binding posts, and your drivers to create a complete system rivaling the appearance of the most lavishly presented audiophile speakers.
Dimensions: 14" H x (8.5" Front, 4.5" Back) W x 13" D.
Note: Cabinet dimensions do not include grill
One of the most innovative features is the exclusive Baffle Replacement and EXchange (B-REX) system, which allows the front baffle to be easily removed for prototyping and construction. The satin black finish baffle has 4 pre-drilled holes for machine screws that line up with matching threaded inserts, to secure the baffle to the cabinet. The baffle can be installed or removed an infinite number of times. This is great for initial driver cutouts, allowing the work to take place on a piece of flat stock, rather than on a finished cabinet.
Thanks to the B-REX system, if you are uncertain whether your speakers are complete, the machine screws by themselves can be used to hold the baffle in place. Once you are ready to finalize the design, they then act as clamps too hold the baffle in place while your glue is setting. Blank baffles are available separately, allowing further possibilities in terms of using a single cabinet for multiple pairs of drivers. As you can see, the versatility offered by the B-REX system is unmatched in any other pre-finished cabinet!
  • BrandDayton Audio
  • ModelTWC-0.50CH
  • Part Number302-723
  • UPC844632059476
  • Product CategoryHi-Fi Speaker Cabinets
    (4 Reviews)
  • Weight19 lbs.
View similar products to the Dayton Audio TWC-0.50CH 0.50 cu. ft. 2-Way Curved Speaker Cabinet Cherry
in the Hi-Fi Speaker Cabinets product category.
